samneric Posted May 26, 2008 Share Posted May 26, 2008 Just replaced the fuse in my A/C system and hooked up the belt to run the compressor and switched it on.... Derlummmm - Engine stalled.Tried starting again with out the A/C and the car ran very poorly, maybe 2000 rpm with max throttle.Figured the timing was out - it was. I advanced a cog and got the timing set up again. A/C on - same thing.I disconnected the A/C belt and tried turning the inner shaft with hands. Very hard to turn.Has anyone seen this before with a compressor and could it cause the dissy to jump a tooth?????? I find it hard to believe that a strong load could cause the dissy to mess up...Gonna look around for a new comp/dryer etc...Steve Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 27, 2008 Share Posted May 27, 2008 I've seen them seize, yes. Don't know about the timing - perhaps your timing belts are loose. GD Link to comment Share on other sites More sharing options...
samneric Posted May 27, 2008 Author Share Posted May 27, 2008 I've seen them seize, yes. Don't know about the timing - perhaps your timing belts are loose. GD No timing belts, should have said. Tis an EA81 with hitachi carb. Have priced a reman comp and dryer. Will get them ordered this week. Need a new carb as well. When spraying carb cleaner about the vac lines and carb, there was definately a lot of rev action going on when cleaner hit the carb. I hear people mention that the weber is just as much of a pain as the Hitachi - what exactly is the major complaint with them? Steve Link to comment Share on other sites More sharing options...
monstaru Posted May 27, 2008 Share Posted May 27, 2008 i have a compressor that i just took off of the wagon.40 bucks shipped.if ya want it.cheers, brian Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 27, 2008 Share Posted May 27, 2008 I hear people mention that the weber is just as much of a pain as the Hitachi - what exactly is the major complaint with them? Not really - it all depends on how you do it. New/used, rebuilt yourself, wireing, plumbing, ect, ect. Once you have done a few it becomes very easy. GD Link to comment Share on other sites More sharing options...
samneric Posted May 27, 2008 Author Share Posted May 27, 2008 i have a compressor that i just took off of the wagon.40 bucks shipped.if ya want it.cheers, brian Sounds great What kind is the comp? Hitachi or the other one? Is it R134 already? Do you also have the carb throttle kick-back lever???? Steve Link to comment Share on other sites More sharing options...
