Subieguy Posted May 27, 2008 Share Posted May 27, 2008 I need to know what vehicle I need to get this 100 amp alternator from. If I remember right it is a GM alt. Just can't remeber what car it would be in. Or maybe a part number for it would work. Also is there anything special I need to do to my Brat when I am putting one in? Thanks, Richard Quote Link to comment Share on other sites More sharing options...
ferox Posted May 27, 2008 Share Posted May 27, 2008 The 100 amp GM's come in a lot of cars. When I did mine I think I found 1980 chevy blazer v8's and cadillacs had them. It's part #7157. In the Engine Electrical section of this forum RavenTBK did a write up on the install. My install didn't go quite like described in that write-up, but it wasn't too hard and was well worth it. That said, you might also consider the 90 amp Nissan Maxima alt. as well. I chose the GM because I know just about every parts store has one, I thought there were minimal mods, and it seemed like the best option for swaps in the field. I did have to do more grinding of the ears than I anticipated(angle grinder required) which defeats my reasoning for going with the GM. I am sure there is some variability in the space between the ears...pun intended but not directed. So if you get one you may not have to grind as much. I also had to put a spacer on the pulley for belt alignment and a spacer on the adjuster bracket (see pic). You will probably want to do some wiring upgrades. I went to #6 for the power supply wire and #12 for the field sensor wire. I have an '81 so I was removing an external voltage regulator at the same time, but yours should be similar. The ignition power wire was factory spliced into the alternator power wire about 16 inches down the alt wire from the fusible link box. If you replace your alternator wire you will have to locate that splice and connect ignition power to your new alt. wire. Here's the bracket spacer. I will make a new one out of thicker metal someday. This one works great so far, but it makes me a little nervous. The field sensor wire should be upgraded and run directly to the main power supply wire just before the fusible links. You can kind of see where the f.s. wire splices into the supply wire (please excuse the toddler-like mouse-writing skills) Finished fitment GD helped me out a lot on this, so if I have made a mistake here he will surely correct me. I would check the Maxima alt. before jumping into the GM. The GM is great, the mods aren't much, but it could/would be a difficult, time consuming swap on the side of the road. Hope this helps Quote Link to comment Share on other sites More sharing options...
Mykeys Toy Posted May 28, 2008 Share Posted May 28, 2008 I borrowed this from a dead thread which can be found here. http://www.ultimatesubaru.org/forum/showthread.php?t=24227&highlight=GM+Alternator Your Palladium P7157 alternator fits the following vehicles: BUICK 1977 CENTURY 1977 ELECTRA 1978 LESABRE CADILLAC 1980-1984 COMMERCIAL CHASSIS 1980-1984 DEVILLE 1980-1985 ELDORADO 1979-1985 FLEETWOOD 1980-1985 SEVILLE CHEVROLET 1984-1985 P30 VAN GMC 1984-1985 P35/P3500 VAN OLDSMOBILE 1979 CUTLASS 1979 CUTLASS CALAIS 1979 CUTLASS CRUISER 1979 CUTLASS SUPREME Good Luck Mike Quote Link to comment Share on other sites More sharing options...
monstaru Posted May 28, 2008 Share Posted May 28, 2008 everything you need to know is in this article by raven.....DOH......i wrote this like three hours ago and it popped up and i just hit reply........ http://www.ultimatesubaru.org/forum/showthread.php?t=64613 Quote Link to comment Share on other sites More sharing options...
Subieguy Posted May 28, 2008 Author Share Posted May 28, 2008 Thank you! Quote Link to comment Share on other sites More sharing options...
monstaru Posted May 28, 2008 Share Posted May 28, 2008 i frequently utilize www.partsamerica.com to cross reference for parts. just put 7157 into the search field and it will turn up this alternator.then you can see a link to what all vehicles it fits.and it will give you a much larger list than above.this is the same list i took with me to the junkyards to procure my last two.cheers, brian also the stock bracket may need to be ground down on the inside(closest to engine side) to allow more up and down movement of the alternator. Quote Link to comment Share on other sites More sharing options...
zukiru Posted May 28, 2008 Share Posted May 28, 2008 89.99 Ftw! Quote Link to comment Share on other sites More sharing options...
kiwi subbie Posted May 29, 2008 Share Posted May 29, 2008 i was thinking i do same thing on my one. but just thought no point since im going to do engine converson Quote Link to comment Share on other sites More sharing options...
subestyle18 Posted May 29, 2008 Share Posted May 29, 2008 Does anyone know what belt works with that alt and no ps or ac? Quote Link to comment Share on other sites More sharing options...
ferox Posted May 29, 2008 Share Posted May 29, 2008 I have a 15365 on my ea81, but it could be a bit different per individual set-up. I estimated with a string and bought three belts. I returned the two that didn't fit. Quote Link to comment Share on other sites More sharing options...
