BobBrumby Posted June 1, 2008 Share Posted June 1, 2008 I have had my 160,000km 95 liberty ej22 for 2500km now with just the one problem. I think one of the injectors is leaking because it takes 3-4 cranks to start if you have not driven it in a while. When you start the engine just after turning it off it starts on the first crank. This happens exactly the same no matter hot or cold, this is why I think it may be a leaky inkector. Should the fuel pump presurise when you key on or when the altinator starts turning like the ea's? Is it just the two o rings per injector? Link to comment Share on other sites More sharing options...
JaySVX Posted June 2, 2008 Share Posted June 2, 2008 3-4 cranks is natural when the engine is cold. First cranks is natural when it's hot. As far as the reason, I'm not certain, but I would guess that there's still fuel vapor in the cylinder when it's hot, where-as when it's cold, the fuel vapor has returned to a near liquid form, thus not as easily combustible, and has to wait until there is fresh vapor in the cylinder before it can ignite. Link to comment Share on other sites More sharing options...
