akjruthies Posted June 3, 2008 Share Posted June 3, 2008 Help! My '97 Outback is leaking fuel! The fuel pump was relaced about two weeks ago. Since then the tank hasn't been any fuller that 1/2 tank. However, I had been smelling fuel on the passenger/rear side of the car (same side as the pump and the fuel filler nozzle). I filled up the tank today and now it is leaking fuel all over the place! I cannot tell where it is leaking. It seems to be leaking and then running down across the bottom of the car and dripping on the driver/rear side of the car. Any suggestions? Link to comment Share on other sites More sharing options...
yohy Posted June 3, 2008 Share Posted June 3, 2008 My guess is it's your fuel filler pipe. Just replaced it on my '97 L sedan. The part is about $110 and is a fairly straight forward replacement....BUT, my car was 5 hours away (kid at school) so it became apx $340 at the dealership. Link to comment Share on other sites More sharing options...
akjruthies Posted June 3, 2008 Author Share Posted June 3, 2008 How can I tell if it is the fuel filler pipe or not? It leaks whether it is idling or not. How do I access the f.f. pipe? Link to comment Share on other sites More sharing options...
yohy Posted June 3, 2008 Share Posted June 3, 2008 Take the passenger side rear tire off and you will see a plastic shroud that covers the fuel filler pipe. The shroud is the culprit as it traps road dirt and debris (salt) right at the bend as the pipe heads towards the fuel tank. In my case, I took off the shroud and was able to see, feel and smell the gas at that point in the pipe. Check this link out, it will give you an exploded view as well as the price. http://www.trademotion.com/partlocator/index.cfm?action=getLocator&siteid=214077&chapter=ARL7521&appSectionid=2782&groupid=2783&subgroupid=4022&componentid=0&make=32&model=Legacy&year=1997&graphicID=7521425&callout=8&catalogid=2 Link to comment Share on other sites More sharing options...
Hocrest Posted June 3, 2008 Share Posted June 3, 2008 I had this same problem on my 97 Leg Sedan. Just a word of warning if you're gonna get a used one from a board member or junkyard. There are two different styles of filler neck. I'm not sure what body, trim or year uses different ones. http://www.ultimatesubaru.org/photos/showgallery.php?cat=882 The first 6 photos in this folder are what I have, the last photo is the one I got from the junkyard that I couldn't use. Link to comment Share on other sites More sharing options...
davebugs Posted June 3, 2008 Share Posted June 3, 2008 I think aftermarket filler tubes are an unmet need. Don't know how bad the liability would be but the dealer price seems pretty steep and the only option. I have one excellent one here and I believe another one (that looks like it was replaced) on a car I'll probably part out this week. I looked for alternative sources and couldn't find any. I'm used to seeing - and replacing the one in the first 6 pics of the last poster. I think they are the same on atleast 95-97 Legacy's - sedans and OB wagons in my experience. Dave Link to comment Share on other sites More sharing options...
forester2002s Posted June 3, 2008 Share Posted June 3, 2008 Word of caution: I would be very hesitant of driving a car that leaked fuel. Why? In one word: FIRE! Link to comment Share on other sites More sharing options...
porcupine73 Posted June 4, 2008 Share Posted June 4, 2008 Fuel fill pipe is in the RH (passenger) wheel well then goes to the tank. There's some rubber type hoses down in there too that could be leaking. Here's the filler pipe after you remove the plastic cover from it: Link to comment Share on other sites More sharing options...
john in KY Posted June 5, 2008 Share Posted June 5, 2008 If you didn't touch the filler tube when the pump was replaced, I would not now suspect it. If you removed a bunch of fuel lines to replace the pump, I would suspect either a line is loose or now cracked. Link to comment Share on other sites More sharing options...
nipper Posted June 5, 2008 Share Posted June 5, 2008 Check the filler, but also check the tank gasket at the fuel pump. Your not supposed to reuse it (i do all the time) but it can be a source of leaks. nipper Link to comment Share on other sites More sharing options...
frag Posted June 5, 2008 Share Posted June 5, 2008 Fuel fill pipe is in the RH (passenger) wheel well then goes to the tank. There's some rubber type hoses down in there too that could be leaking. Here's the filler pipe after you remove the plastic cover from it: There seems to be a repair of some sort on your filler pipe. What did you do exactly ? Link to comment Share on other sites More sharing options...
