Stuck needle valve in the carb
It may be more like the float is stuck. Remove the carb and seperate the top from the body and take a look. I had this happen on an 86 EA82 3-door, it would only idle. The float was twisted a bit and rubbing the side of the float chamber. A good rebuild kit will have the needle and seat, as well as the gaskets needed to take it down and clean it. They're not much of a rebuild kit anymore.
