FlatBlackS00b111 Posted June 4, 2008 Share Posted June 4, 2008 I just got a 78 wagon and i once saw one that was lowered. How can i lower the rear with those torsion bars? Quote Link to comment Share on other sites More sharing options...
stealth Posted June 27, 2010 Share Posted June 27, 2010 Sorry to necro this thread up, Im trying to lower a 79 wagon but the rear torsion bars are nothing like i have ever seen before, is it a matter or winding up/down to lower/raise, if so is there any guidelines or walkthrus to this? I have lowered several other models with torsion bars (mainly utes) but im not sure on how this setup in the rear works, Any help would be apprecieated. thanks Quote Link to comment Share on other sites More sharing options...
stealth Posted June 27, 2010 Share Posted June 27, 2010 yeah all you gotta do is unbolt the 3 17mm's on the trailing arm and the 12mm that is underneath the tube near the end then just tap the trailing arm out with a hammer clean up the splines a bit and spray on some wd40 or anything like that to make things much easier then just position the trailking arm at the height you would like and slide it back in chuck the 3 17mm's back in and the 12mm at the bottom and youre done and you have gotta do it oin both sides i have done this before on a wagon... not really the best solution:confused: if you go as low as it looks like your front is, then you will basically be riding on the bumpstops in the rear you can get some extra suspension travel by removiong the bumpstops (they are meant to screw out, but ive never been able to) a setup similar to the rear of the l series would be the go, stiffen the rear up and have short stroke shocks and you should be laughing found this in another thread, guess to keep looking to find what ya after, sorry. Quote Link to comment Share on other sites More sharing options...
Pooparu Posted June 28, 2010 Share Posted June 28, 2010 Hmmmmm, you want to lower it like this one? Quote Link to comment Share on other sites More sharing options...
sti-nkr Posted July 2, 2010 Share Posted July 2, 2010 I want to do that to my Brat! Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted July 6, 2010 Share Posted July 6, 2010 Here's my Brat with the springs and bumpstops taken out of the front and the torsion bars cranked down after half the rear bumpstops were cut off. Quote Link to comment Share on other sites More sharing options...
