zukiru Posted June 4, 2008 Share Posted June 4, 2008 like does a Phase II EJ25 have the cam cover/slot for a distributor? I am not wanting to use a distributor but a CAS for a DSM for megasuirt and spark. Link to comment Share on other sites More sharing options...
nipper Posted June 4, 2008 Share Posted June 4, 2008 No it was never designed for a dist. nipper Link to comment Share on other sites More sharing options...
Gloyale Posted June 4, 2008 Share Posted June 4, 2008 Not as easy as the 2.2, but it might be doable. There is a plug at the rear of the head for Camshaft like the 2.2. Pull the cam retainer/rocker carrier assembly off the head and the plug should be free to come out. From there it's just a matter of finding a disty to fit, and a way to bolt it down. Probably require some machining/welding tabs to the head. Link to comment Share on other sites More sharing options...
zukiru Posted June 4, 2008 Author Share Posted June 4, 2008 thanks that's what I wanted to know.. I saw someone running a DSM CAS on another engine for MS-n-spark and it worked fine... my engine will be here end of the month. I wanted to know if I had cam acces on the back of the head! I may have to weld tabs and that's all good! Link to comment Share on other sites More sharing options...
Numbchux Posted June 5, 2008 Share Posted June 5, 2008 IIRC the DOHC ones don't have the place for it....but the SOHC ones might. Link to comment Share on other sites More sharing options...
zukiru Posted June 5, 2008 Author Share Posted June 5, 2008 it matters not if I have to I'll run EDIS. Link to comment Share on other sites More sharing options...
zukiru Posted July 8, 2008 Author Share Posted July 8, 2008 it "could" work on an EJ25 you'd need to grind cam slots and make up an adaptor bracket. not something I want to try... Link to comment Share on other sites More sharing options...
