ej25 phase II does it have the disty space?
zukiru
Not as easy as the 2.2, but it might be doable.
There is a plug at the rear of the head for Camshaft like the 2.2. Pull the cam retainer/rocker carrier assembly off the head and the plug should be free to come out. From there it's just a matter of finding a disty to fit, and a way to bolt it down. Probably require some machining/welding tabs to the head.
thanks that's what I wanted to know.. I saw someone running a DSM CAS on another engine for MS-n-spark and it worked fine... my engine will be here end of the month. I wanted to know if I had cam acces on the back of the head! I may have to weld tabs and that's all good!
  • 1 month later...
