Why does the Motor Shake when on the Brake Pedal??
'86 carbed EA82 manual..when stepping on the brake pedal More then Once will cause the motor to shake momentarily ..I have installed new clamps on the vac hose going to the brake booster, but still no difference, and I have also sprayed carb cleaner around the other connections surrounding the carb..all seems to be tightly sealed
