BoostedBalls Posted June 9, 2008 Share Posted June 9, 2008 I tried to check my codes today in my 91 SS. I connected the green connectors under the dash on the left side then switched the key to run. All the warning lights came on and the cooling fan cycled on and off repeatedly. No flashing CEL and no flashing LED on ECM. (if there is one) Is there something I'm missing??? Link to comment Share on other sites More sharing options...
lmdew Posted June 9, 2008 Share Posted June 9, 2008 Connect the black connectors close by the green one. Green puts the car in the D-Check mode, cycles through all the relays and sensors. Black will pull the codes Green and black at the same time will clear the codes Link to comment Share on other sites More sharing options...
BoostedBalls Posted June 9, 2008 Author Share Posted June 9, 2008 sweet, thanks for that. Link to comment Share on other sites More sharing options...
BoostedBalls Posted June 9, 2008 Author Share Posted June 9, 2008 I only see one black connector right near the green ones but it's only a single connector. There is a pair of black connectors above the driver's right knee but they are already plugged in. Link to comment Share on other sites More sharing options...
lmdew Posted June 10, 2008 Share Posted June 10, 2008 That's it, single plug about 1/4" wide. The other half may still be tapped up to the harness. It's there. Link to comment Share on other sites More sharing options...
BoostedBalls Posted June 10, 2008 Author Share Posted June 10, 2008 I found it! I got codes: 35, 44, 22, 32, 42, and maybe a 12,13, 14 Link to comment Share on other sites More sharing options...
BoostedBalls Posted June 10, 2008 Author Share Posted June 10, 2008 so I got: 13- TDC sensor 22- ? 24- Air control valve or circuit 32- O2 sensor 35- PURGE SOLENOID!!! 42- Idle switch 44-? WTF? something is FUBAR, maybe the purge solenoid? I think I'll esearch that now... Link to comment Share on other sites More sharing options...
OB99W Posted June 10, 2008 Share Posted June 10, 2008 so I got: 13- TDC sensor 22- ? 24- Air control valve or circuit 32- O2 sensor 35- PURGE SOLENOID!!! 42- Idle switch 44-? [...] I assume "Boosted" refers to a turbo , so I think the correct code definitions are as follows:13 - Cam Position Sensor 22 - Knock Sensor or Circuit 24 - Air Control Valve or Circuit 32 - Oxygen Sensor or Circuit 35 - EGR Solenoid or Circuit 42 - Idle Switch or Circuit 44 - Wastegate Duty Solenoid (Turbo Models) With that many simultaneous DTCs, I'd suspect something common to all of them. There might be an ECU-related problem, possibly something as simple as a poor ground connection. Link to comment Share on other sites More sharing options...
BoostedBalls Posted June 10, 2008 Author Share Posted June 10, 2008 Yeah, the O2, wastegate solenoid and knock sensor codes were likely from me messing with them. But I haven't touched the purge solenoid. The car does seem to run a bit rich; I can smell heavy exhaust, no smoke though. I'll clear all the codes and then try disconnecting the purge solenoid and see how it runs. Then maybe I'll try sucking some seafoam through the solenoid. After that, I'll try running a fresh ground to the ECU. Link to comment Share on other sites More sharing options...
BoostedBalls Posted June 10, 2008 Author Share Posted June 10, 2008 I cleared all the codes and the car drove beautifully for 9 miles. I then checked the codes again and there are none stored! I got wood! Link to comment Share on other sites More sharing options...
