crazylong127 Posted June 11, 2008 Share Posted June 11, 2008 i have an 87 dl. it has push button 4wd. and lately the 4wd hasn't been engaging. what all could cause this? it used to work all the time. Link to comment Share on other sites More sharing options...
zukiru Posted June 11, 2008 Share Posted June 11, 2008 the system works by using the switch (button) to open a solenoid that lets vacuum move the lever on the transmission. the first thing I would check is the vacuum lines to that area! this has been covered a bit and a search will net you more info! Link to comment Share on other sites More sharing options...
crazylong127 Posted June 11, 2008 Author Share Posted June 11, 2008 yeah i searched for a little before i posted, then after i searched more and found what i needed. one of the vacuum connections is broken. thanks for the help Link to comment Share on other sites More sharing options...
