Juan Posted March 24, 2014 Share Posted March 24, 2014 Job location changed and I ran two quarts low all of a sudden *(over six months) when I began driving 30 minutes round-trip per day at speeds of 65-75 mph at 3k+rpm. I NEVER had a problem with oil consumption over same milage/time interval traveling surface streets to work -the Subie shop would have mentioned it, right? I'm back to surface streets, new job location, same milage/time interval and have added 1/2 quart over past six months to keep it topped up. Sure, NOW I check my oil at each fill up. Sure, NOW I'm going to replace the PVC valve. Sure, NOW I'm going to ask the Subie dealer, 30+ oil changes and 100,000 miles since new, why they have never mentioned PVC valve. I have never believed in 3,000 mile oil changes. I peg it at 5,000. When is the best time to check oil level? Stone cold? Fire hot? Luke warm? I get different readings between the notches/holes at different temps. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 24, 2014 Share Posted March 24, 2014 I always check first thing in the morning before the car is started for the day. This allows the oil to settle into the pan overnight, and ensures the oil level will be accurate. After the engine has been running a lot of oil is still in the heads and dripping down from the block. If you check the oil level immediately after turning the engine off, then check again an hour later you will get different readings as the oil settles out of the crank-case back down into the pan. Link to comment Share on other sites More sharing options...
Cougar Posted March 26, 2014 Share Posted March 26, 2014 I helped a friend out some time ago with his Loyale that was blowing so much smoke out the tail pipe is was like going through a smoke screen. Fortunately he had a new spare PCV valve in the garage. We changed it out to see if that worked and then there was no more smoke. Easy fix. Link to comment Share on other sites More sharing options...
lmdew Posted March 26, 2014 Share Posted March 26, 2014 (edited) 2003 2.5 Impreza SOHC had been using approx. a 1qt every 200 miles. - New Subaru PCV help some but did not cure the usage - All Hoses hooked up correctly - Only 3% leak down - No External leaks - Seafoam no change - MMO no change - Last attempt ran the Gunk Engine cleaner at idle for about 30 minutes (way longer the specified on the instructions) as it worked I could hear the engine change. So far so good, 200 miles and no oil usage, no smoke. Only 154K on the motor with new HG due to the bent valves of the timing going for the PO. I usually would not use the Internal "Cleaners" but I was down to pulling the engine apart so nothing to loose. Edited March 26, 2014 by lmdew Link to comment Share on other sites More sharing options...
MilesFox Posted March 26, 2014 Share Posted March 26, 2014 My 98 forester with frankenmotor and new seals was using 1 qt a week. i was able to reduce consumtion to 1 qt every 2 weeks by replacing the PCV valve, until the ring land broke. i'm sure the oil was being used past the rings as well, but the PCV did help a lot in that regard. I have had success rejuvinating old oem PCV vlves by sea foaming them. I work at an oil change shop, and some later model cars come in with low oil at 3000 miles, and these are cars with moderate miles, and unserviceable PCV's. I noticed toyota uses the same type of pcv, but unfortunately, our shop doesn't stock this type of PCV valve. And with failed pcv valve in mind, there are some late model engines coming in with 'rear main seal leaks', and i would bet suggesting a PCV valve would help that. Link to comment Share on other sites More sharing options...
subnz Posted March 28, 2014 Share Posted March 28, 2014 usally give mine (PCV valves) a good swim in petrol and that does the trick. Link to comment Share on other sites More sharing options...
forester2002s Posted March 28, 2014 Share Posted March 28, 2014 I spray WD-40 into the PCV valve periodically, and then give it a good shake before reinstalling it. After doing this for 10 years on my Forester, I felt guilty and bought a new PCV valve. But I've kept the old one as a spare, because it seems to be perfectly serviceable. Link to comment Share on other sites More sharing options...
efseiler Posted April 1, 2014 Share Posted April 1, 2014 For the lack of a $15 part, engines are lost. That reminds of something I read in MAD magazine years ago... Problem: Screw broken. Solution: Replace entire engine. a.k.a How union labor stays in business. Link to comment Share on other sites More sharing options...
efseiler Posted April 1, 2014 Share Posted April 1, 2014 I've had problems with oil consumption like that....sometimes I drive 100 miles and it's down like almost an entire quart. Other times I've gone almost 3000 miles and it's down only like a quarter quart. It depends a lot on what you're driving through but weird stuff does happen...I got a bunch of stories about that. I use Lucas additives in the pan and tank...it doesn't cost much and basically works. Link to comment Share on other sites More sharing options...
hudsonfamily Posted November 4, 2014 Share Posted November 4, 2014 Our 2012 Outback has consumed oil excessively since the day we got it. (excessive = 1.3 qt/1200 miles) This is many times more than any car we or any extended family have ever owned, which is dozens of cars and at least 10 manufacturers. The dealer has insisted that "up to 1qt/1200 miles is normal and as-designed. Lousy design. I don't know if they ever checked the PCV or rear separator plate (I'll ask tomorrow), but they now have offered the following: "We will install a new valve cover, inside of which there are a series of baffles. These keep the normal oil inside the of the valve cover from getting to the PCV valve, but Subaru has found some oil getting past one of the baffles allowing the PCV to pick up the oil. The new valve cover is supposed to keep that from happening. The new part number is 13728AA291" I don't know if anyone else has experience with this, but I'm interested in any info. Thanks Link to comment Share on other sites More sharing options...
CNY_Dave Posted November 4, 2014 Share Posted November 4, 2014 Dealer is a stinking liar- but that's the lie subaru tells them to say. No car is designed to burn a quart per thousand or 2 thousand or 3 thousand... 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 5, 2014 Share Posted November 5, 2014 ... Subaru has found some oil getting past one of the baffles allowing the PCV to pick up the oil. The new valve cover is supposed to keep that from happening. The new part number is 13728AA291 ... In the Old School Subarus, something similar happened with the EFi Subaru EA82 Engines, and they then sold a Re-Routing Kit for the PCV System, in order to avoid the PCV Valve to Suck oil; let me share a Post here, taken from Another thread: ...certain EFI EA82's also has problems with their PCV System Sucking Oil, So Subaru made a PCV Re-Route Kit for those models affected with the Original PCV Routing Flaw. Part Number: SUBARU 11813AA010 You can Download a .Pdf file which has the Subaru Recall Info, and the install Procedures, ~► Here. Could a bad PCV system routing, be affecting this EJ engines? Kind Regards. 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 5, 2014 Share Posted November 5, 2014 ... No car is designed to burn a quart per thousand or 2 thousand or 3 thousand... I Agree, Absolutely. So, maybe a re-routing of the PVC system could help? Or only a New PCV Valve? What causes the Problem on these Subies? Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 5, 2014 Share Posted November 5, 2014 The dealer has insisted that "up to 1qt/1200 miles is normal and as-designed. Lousy design. This is considered normal for most engines during the break-in period, during the first 1,000 - 5,000 miles. After that, about half a quart or less per 3,000 miles is what I would consider normal. Burning that much oil suggests excessive piston ring or cylinder wall wear. If you're still within the warranty period, keep pressuring them to do something about it. Link to comment Share on other sites More sharing options...
Bushwick Posted November 5, 2014 Share Posted November 5, 2014 (edited) I'm glad this thread was revived. Noticed my oil was lower than normal yet no external leaks. PCV was the only thing that wasn't replaced when the car was purchased last year. Also getting erratic idle. Will have to check if it's clogged. FWIW, oven cleaner with lye will remove any and all oil deposits (even varnish off the metal which brake cleaners won't) including heavy sludge. Spray in, let it set for several minutes, then spray out with water. Dry immediately. Might need to do a second time if the oil is coked really bad and use a pipe cleaner to hasten the job. Best thing is the generic oven cleaners are $2 a can at Giant Eagle. As long as the cleaned valve permits flow in the one direction and not the other, it should still be usable. (Disclaimer: lye is VERY caustic to the skin and can cause burns. Should avoid breathing the vapors as well. It's excellent at cleaning cast iron and steel, but will dull polished aluminum.) Edited November 5, 2014 by Bushwick Link to comment Share on other sites More sharing options...
def Posted November 5, 2014 Share Posted November 5, 2014 After finding this thread, I replaced my PCV valve on my 2009 Impreza several months ago. I bought this car new and from early on I was getting excess oil consumption and the smell of oil while driving but could not find any sign of an oil leak. My old PCV was not oily and you could hear the movement inside the valve when you shook it. I replaced it anyway since it was out and I had the new one in hand. Since I replaced it, I no longer have the smell of oil while driving. I believe my oil consumption was reduced as well, but I still have to add oil between changes. Link to comment Share on other sites More sharing options...
SnatchedHatch Posted November 5, 2014 Share Posted November 5, 2014 I bet that's where my oil has been going..... silly 2.5T.... and I thought it was because I beat the snot out of it :-p No no, you're thinking of your head gaskets which will no doubt be missed Link to comment Share on other sites More sharing options...
SnatchedHatch Posted November 5, 2014 Share Posted November 5, 2014 (edited) Our 2012 Outback has consumed oil excessively since the day we got it. (excessive = 1.3 qt/1200 miles) This is many times more than any car we or any extended family have ever owned, which is dozens of cars and at least 10 manufacturers. The dealer has insisted that "up to 1qt/1200 miles is normal and as-designed. Lousy design. I don't know if they ever checked the PCV or rear separator plate (I'll ask tomorrow), but they now have offered the following: "We will install a new valve cover, inside of which there are a series of baffles. These keep the normal oil inside the of the valve cover from getting to the PCV valve, but Subaru has found some oil getting past one of the baffles allowing the PCV to pick up the oil. The new valve cover is supposed to keep that from happening. The new part number is 13728AA291" I don't know if anyone else has experience with this, but I'm interested in any info. Thanks Is your Outback the 6 cylinder model? My family's 2011 3.6 has been burning oil lately, but usually only under stress: i.e. two road trips with the car loaded. They had showed a (I believe valve cover plate) and how dirty it was, whichever piece it was, they insisted it had tiny channels for some sort of valve that can get clogged up. Now that I think about it, it was to the Crankcase, so PCV it must be. On two occasions, the head mechanic pulled one of these clogged plates from a pile lol, and spewed what we took as rubbish. They insisted a "proper" oil maintenance schedule should be followed with something like once every 3,000 miles for these 6 cylinders. Otherwise the plates get gunked up and you know the rest, as for simply reconditioning/cleaning the plate, I was told and shown by the mechanic that's been there for years, that it's quite impossible to clean, and the channels are riveted into the plate... non-removable by their standards. What I took from this, is the covers do have a pseudo-design flaw, we have been adhering to their oil schedule just to ensure warranty coverage, 5k is what we went with for the first few oil changes (besides the very first). Hudsonfamily, my family just drove to FL from the midwest and had the car checked at a dealer down there. I'll find out how "our's" is doing, but above all else, KEEP BUGGING THE DEALER and get as many records of these issues as you can early on. That's what they're doing. Edited November 5, 2014 by SnatchedHatch Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 5, 2014 Share Posted November 5, 2014 As long as the cleaned valve permits flow in the one direction and not the other, it should still be usable. Not always true. I've seen enough clean and free (still rattle) PCV valves cause oil consumption problems that I just replace them if they're heavily sludged. I only clean them as a preventative matter. If they're plugged, I replace them when viable. Link to comment Share on other sites More sharing options...
Bushwick Posted November 5, 2014 Share Posted November 5, 2014 (edited) Not always true. I've seen enough clean and free (still rattle) PCV valves cause oil consumption problems that I just replace them if they're heavily sludged. I only clean them as a preventative matter. If they're plugged, I replace them when viable. Not sure how elaborate these valves are as opposed to other cars, but it's designed to only allow flow in one direction. As long as it's working correctly, it can be reused. Also, you can get oil consumption with a brand new PCV. Turbo cars are more prone (in general). If oil makes it's way pass the valve cover baffling and get's into the hose, it can over time get sucked into the intake and down into the throttle body. Best bet if it's happening a lot is to install a catch can OR have a drain back device installed, though the catch can is better as you aren't risking contaminants getting drained back. Some engines have less than ideal PCV systems. Edited November 5, 2014 by Bushwick Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 5, 2014 Share Posted November 5, 2014 I could see how one might rattle, but the seat could be rough and not seal well. I dunno, they're pretty cheap to buy. Link to comment Share on other sites More sharing options...
grimaceNMike Posted November 6, 2014 Share Posted November 6, 2014 (edited) While changing my pcv valve I noticed the hose's were caked in sludge. Still enough to breathe, but clogging for sure. I managed to clean the longer hose but this Y connector (picture) would not come off the engine. I didn't want to scrape the sludge back into the crankcase... So what do I do? Edited November 6, 2014 by grimaceNMike Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 6, 2014 Share Posted November 6, 2014 The large hose on that one usually breaks (after you break the Y part first). Last one I did I had a heck of a time finding emissions hose that large. Ended up cutting up an old IAC hose. Literally had to chisel the old hose off the fitting on the block. The hose broke off at the bottom and left the last inch or so on the block. The thing was brittle as glass. I was able to get a small pick in around the Y fitting and the hose broke around that too and I was able to get the Y out without breaking it. A little silicone grease in the new hose and it all went back together easy. Link to comment Share on other sites More sharing options...
grimaceNMike Posted November 6, 2014 Share Posted November 6, 2014 The large hose on that one usually breaks (after you break the Y part first). Last one I did I had a heck of a time finding emissions hose that large. Ended up cutting up an old IAC hose. Literally had to chisel the old hose off the fitting on the block. The hose broke off at the bottom and left the last inch or so on the block. The thing was brittle as glass. I was able to get a small pick in around the Y fitting and the hose broke around that too and I was able to get the Y out without breaking it. A little silicone grease in the new hose and it all went back together easy. That's what I'm afraid of doing! I practiced at the junkyard and I couldn't get it out of the block without breaking it.. Can I just get a bottle brush and some seafoam and go to town on it? Then do an oil change immediately? Or would the chunks remain in the crankcase? Link to comment Share on other sites More sharing options...
lmdew Posted November 6, 2014 Share Posted November 6, 2014 Just pull it off the engine and get an junk yard iac hose to replace it. 1 Link to comment Share on other sites More sharing options...
