1983 brat carb problems.....
may not be related, but mine had that flat spot in it the first couple years i had it (thought it was just the way the car ran) and i advanced the timing from 8^ to 10^ BTDC and it eliminated the flat spot and gave it lots more power.
also the only gas i run is amoco (BP) 93 oct.
hope it helps,
thanks, Bill
i'm not really qualified to give any advice, just suggestions based on my 3 year struggle to keep mine running.
that being said, i'm not sure what your motors timing is supposed to be set at specifically so i cant give you specific numbers.
but if you have the ability to check and reset the timing properly and accurately then i personally would try advancing it a couple degrees ahead of factor specs (as long as it dont make it ping) and see.
made a world of difference in mine.
especially if you have time to kill waiting on other parts anyhow.
good luck
Bill
