()__1337_CRAYOLA__()> Posted June 23, 2008 Share Posted June 23, 2008 how hard is it to change the oil pump gasket car still has good oil pressure... 25 at idle and 50 at cruise. also the pan gasket is leaking to how hard is that to change i notice there are a few bolts on the back of the pan covered by the crossmember. does this require unbolting the motor mounts and jacking it up? Quote Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted June 23, 2008 Share Posted June 23, 2008 Really easy. Oil pan on the other hand...I'd imagine you'd have to jack the engine up a little, with the mounts unbolted. Quote Link to comment Share on other sites More sharing options...
hatchsub Posted June 23, 2008 Share Posted June 23, 2008 Ive done an oilpan gasket on an EA81 without pulling or jacking up the engine. It wasnt fun but it was doable. Subaru was nice and drilled holes in the crossmember just big enough to get a socket and extention through to the back few bolts that hold the pan on. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 24, 2008 Share Posted June 24, 2008 EA81 oil pans have no baffle plates like EA82's. There is no need to jack up the engine. It's actually quite easy. I use a large phillips screwdriver for the back bolts. They come out easily. GD Quote Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted June 25, 2008 Share Posted June 25, 2008 EA81 oil pans have no baffle plates like EA82's. GD That's good to know, I've only done EA82s. On a side note, can the pans swap out? If not, is there a benefit to adding baffles for high angle applications? Quote Link to comment Share on other sites More sharing options...
