Buick350X Posted June 23, 2008 Share Posted June 23, 2008 Now we got an 00 Forest with a 2.5, has near 130,000 on the clock. It doesn't leak or blow smoke, O2 sensors aren't failing but its using up allot of oil. We will watch n watch it with no change then the next time you forget to check, its a quart or more low. Was near 2 quart low but thank god the alarm wire had broken lose, shorting out the spark while driving so we looked everything over. Its just so odd, my experiance with old american cars is when they use or leak oil you can catch it and keep it full with little work but this forign sucker has no rhym or reason to the oil loss........... Quote Link to comment Share on other sites More sharing options...
chef_tim Posted June 23, 2008 Share Posted June 23, 2008 Place to start...... http://www.ultimatesubaru.org/forum/showthread.php?t=89549 Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted June 23, 2008 Share Posted June 23, 2008 Place to start......http://www.ultimatesubaru.org/forum/showthread.php?t=89549 Same thought before reading link, replace your PCV valve, hope that fixes your disappearing oil problem. Quote Link to comment Share on other sites More sharing options...
Buick350X Posted June 24, 2008 Author Share Posted June 24, 2008 Oh man was that thing crusty, full of garbage, these newer computer cars run so good for so long its easy to for get stuff like it. Im hoping that and the hi mile oil will seal up them leaky gasket since they only leaked from to much crank case pressure. And only leaked at random since oil goes MIA at random times. Quote Link to comment Share on other sites More sharing options...
