()__1337_CRAYOLA__()> Posted June 25, 2008 Share Posted June 25, 2008 Its done only took me 2 hours My question is what is this and how do i removed it i capped it for now unless im told not to or how to remove it cause it's loud! P.S. GD this is what my kit cam with roight out of the box cause u were wondering Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 25, 2008 Share Posted June 25, 2008 Its done only took me 2 hours Right on - looks good except your PCV and breather lines aren't routed correctly/at all. You need to T both valve covers and the PCV valve into the white elbow on the bottom of the Weber filter. And you don't need to put vacuum caps on all the old "hardlines". Those go nowhere now as you should have disconnected all of the items they once supplied. They are not attached to the manifold - it's just a big spider-like thing composed of a bunch of steel tubing that's bolted to the underside of the manifold. My question is what is this and how do i removed it i capped it for now unless im told not to or how to remove it cause it's loud! That's the air suction valve. Look behind the valve itself and you'll see where the tube from the exhaust spacer threads into it. Remove the two 12mm bolts holding the valve to it's bracket and unthread the flare fitting for the tubing. Drop a quarter (yes - $0.25) into the valve and reinstall it. This will effectively "shut it off". You don't need it and it's not doing anything useful for you. If you want more info on them do a search for "ASV" or Air Suction Valve. They supply oxygen-laden air for part of the old-style catalytic converter to function more effeciently. P.S. GD this is what my kit cam with roight out of the box cause u were wondering That's a lot better than my kit. Glad they take sugestions on this stuff apparently. Mine was horrible - didn't include any of that linkage stuff, had the 3" filter, and the adaptor plate. And it cost me $399 back in like '03. Oh well - live and learn. My last one cost $190 cause I built it myself . GD Quote Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted June 25, 2008 Author Share Posted June 25, 2008 so is it pretty good that the car fires right up after i primed it and all i had to do was turn the idle screw down a little bit to idle at 800 rpm Quote Link to comment Share on other sites More sharing options...
Petersubaru Posted June 25, 2008 Share Posted June 25, 2008 so is it pretty good that the car fires right up after i primed it and all i had to do was turn the idle screw down a little bit to idle at 800 rpm..Just curious here,(without having to remove the jets)... but would you know from the info provided as to what size the "primary and secondary idle jets" would be Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 26, 2008 Share Posted June 26, 2008 ..Just curious here,(without having to remove the jets)... but would you know from the info provided as to what size the "primary and secondary idle jets" would be Should be 50's. Kit contents may change, but jetting wouldn't. GD Quote Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted June 26, 2008 Author Share Posted June 26, 2008 me driving with my very VERY heavy foot i got 24 MPG the plugs are PERFECT color no complaints i wonder what kinda gas milage i could get if i drove with a egg under the peddle also thats around town to work and back haha Quote Link to comment Share on other sites More sharing options...
hatchsub Posted June 26, 2008 Share Posted June 26, 2008 I get 30mpg on the highway with a slightly heavy foot. You will probably see 30 if your not stomping on it. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 26, 2008 Share Posted June 26, 2008 I get 30mpg on the highway with a slightly heavy foot. You will probably see 30 if your not stomping on it. Brat = 4WD, so probably not. Gearing differences. Freeway he should see around 27 maybe 28. GD Quote Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted June 26, 2008 Author Share Posted June 26, 2008 by the way how big is a 1983 gl brat gas tank my gas gauge is broken hahaha just go 200 miles and fill it? Quote Link to comment Share on other sites More sharing options...
