()__1337_CRAYOLA__()> Posted June 26, 2008 Share Posted June 26, 2008 Cruise Limit : HC (PPM) 220 CO (%) 1.2 Cruise Emissions: 462(FAIL) 5.13 (FAIL) Idle Limit: HC (PPM) 220 CO (%) 1.2 Idle Emissions 1192(FAIL) .44 (PASS) Anyone have a idea on whats going on or anyone had this problem with theres.... engine was rebuilt 50,000 ago and is still tight very little blow by runs smoooth no misses..... turbo still alive and kicking no oil leaks or burning im at my end with this subaru it's about to go to the Junk Yard Link to comment Share on other sites More sharing options...
4WDFrenzy Posted June 26, 2008 Share Posted June 26, 2008 Cruise Limit : HC (PPM) 220 CO (%) 1.2Cruise Emissions: 462(FAIL) 5.13 (FAIL) Idle Limit: HC (PPM) 220 CO (%) 1.2 Idle Emissions 1192(FAIL) .44 (PASS) Anyone have a idea on whats going on or anyone had this problem with theres.... engine was rebuilt 50' date='000 ago and is still tight very little blow by runs smoooth no misses..... turbo still alive and kicking no oil leaks or burning im at my end with this subaru it's about to go to the Junk Yard[/quote'] Let me ask a question(possibly stupid). Is it all stock, or are there any modifications done? Patrick Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted June 26, 2008 Author Share Posted June 26, 2008 completely stock..... Link to comment Share on other sites More sharing options...
idosubaru Posted June 26, 2008 Share Posted June 26, 2008 plugs, wires, cap and rotor, and PCV valve. Link to comment Share on other sites More sharing options...
robm Posted June 26, 2008 Share Posted June 26, 2008 MAF and/or O2 sensor? CTS telling the ECU to run open loop/cold enrichment? Leaky injector? It is running way rich, for some reason. Link to comment Share on other sites More sharing options...
Turbone Posted June 26, 2008 Share Posted June 26, 2008 I would try replacing the 02 sensor and if its a 86, it has the flapper style MAF. Not much to clean on that but the door linkage. Link to comment Share on other sites More sharing options...
suberdave Posted June 27, 2008 Share Posted June 27, 2008 i had the same problem with my last EA82T. when it was at idle the O2 sensor would go flat, then run rich. to fix it i put in a heated three wire O2 sensor. then it flew through emmissions. just a good new sensor may have worked but i had a custom downpipe with no cat or heat shelds. i think the cat in the downpipe helps keep it up to temp at idle. -=Suberdave=- www.suberdave.com Link to comment Share on other sites More sharing options...
joostvdw Posted June 27, 2008 Share Posted June 27, 2008 Also check your ignition timing, I ran with 35degree BTDC for a while (no it wasn't intentional and no it didnt detonate or knock) and it had immense HC emissions, like 1400PPM at idle So make sure yours is at 20/22 degrees @ 700rpm. Link to comment Share on other sites More sharing options...
Pooparu Posted June 27, 2008 Share Posted June 27, 2008 i had the same problem with my last EA82T. when it was at idle the O2 sensor would go flat, then run rich. to fix it i put in a heated three wire O2 sensor. then it flew through emmissions. just a good new sensor may have worked but i had a custom downpipe with no cat or heat shelds. i think the cat in the downpipe helps keep it up to temp at idle. -=Suberdave=- www.suberdave.com I took the upper cat off of my old EA82T and put on one hotter cat. It passed with flying colors. If I were you I'd try just changing the oil as well and make sure the car is good and warmed up before running the test. Link to comment Share on other sites More sharing options...
presslab Posted June 27, 2008 Share Posted June 27, 2008 o2 sensor +1 Check the cycle count or just make sure it's toggling with a multimeter. Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted June 27, 2008 Author Share Posted June 27, 2008 . Link to comment Share on other sites More sharing options...
