Strange Leak
  Bucky92 said:
Could be your windshield..and leaking down behind the dash..feel the base of the window for wetness..and also around the bottom of the dash..feel along the firewall too...it could be going behind the carpet
I felt anong side the door and its wet there. The winshield doesnt apear to have any problems in that area.
Ill check anyways though.
Ben
I had some problems with the drains right in front of where the wipers mount. I ran an old bass guitar string down in there and cleared all the crud out. Maybe that will help your problem.
Also you could get the hose out and have someone spray it down while you look for the leaks inside.
