Quick Forester engine question
Hey all:
Just a quick question........does a 1999 Forester Phase 2/2.5 have the same plastic oil separator plate on the back, as the mid-90s 2.2s? Or did they change it to metal? So then is the metal replacement plate the same for the 2.2s and the 2.5s?
Thanks!
Todd
I owned a 99 Forester. It definitely has the idiotic plastic separator plate. It is guaranteed to warp and leak oil. The engine or transmission has to be pulled to replace it. So, if you ever have the chance, replace it.
the separator plates are all the same, but the newer ones also require different screws some times (or all the time?). not sure if that depends on the "old one" or not?
There are different style seperator plates, all interchange, 2 use the same screws.
Cast Aluminum- uses phillips head screw oldest style don't leak
Plastic- uses phillips head screws middle years, big leakers
Stamped steel- uses different bolts 6mm thread 10mm head latest update, what dealers sell now
Hope that clears it up
