somick Posted June 28, 2008 Share Posted June 28, 2008 I received an e-mail from Rockauto with close out prices: Brake/Wheel Hub BECK/ARNLEY Brake Pad - Front $8.49 BECK/ARNLEY Brake Shoe $8.27 BECK/ARNLEY Caliper $37.79 RAYBESTOS Caliper Repair Kit $1.71 BECK/ARNLEY Disc Brake Hardware Kit $9.74 BECK/ARNLEY Drum $60.79 BECK/ARNLEY Drum Brake Hardware Kit $8.58 BECK/ARNLEY Hydraulic Hose $6.78 BECK/ARNLEY Master Cylinder $75.79 BECK/ARNLEY Rotor - Front $24.79 DORMAN Wheel Cylinder $6.70 BECK/ARNLEY Wheel Cylinder $11.80 RAYBESTOS Wheel Cylinder $6.46 TIMKEN Wheel Oil Seal $2.78 BECK/ARNLEY Wheel Oil Seal $1.74 Cooling System BECK/ARNLEY Thermostat $3.10 BECK/ARNLEY Water Pump $26.79 BECK/ARNLEY Water Pump Gasket $0.53 Drivetrain BECK/ARNLEY CV Joint Boot $5.08 Electrical-Switch & Relay BECK/ARNLEY Oil Pressure Switch $3.06 Emission BECK/ARNLEY Oxygen Sensor $21.99 Engine BECK/ARNLEY Cylinder Head Gasket Set $55.79 BECK/ARNLEY Intake Manifold Gasket $1.40 FRAM Oil Filter $3.56 BECK/ARNLEY Oil Pan Gasket $2.85 BECK/ARNLEY Valve Cover Gasket Set $3.59 Fuel/Air FRAM Air Filter $4.38 BECK/ARNLEY Air Filter $3.33 FRAM Fuel Filter $8.30 Ignition BECK/ARNLEY Distributor Cap $4.52 BOSCH Distributor Cap $3.85 BOSCH Distributor Rotor $2.46 ACDELCO Spark Plug $1.12 BECK/ARNLEY Spark Plug Wire Set $10.78 Steering BECK/ARNLEY Tie Rod End $16.75 Suspension GABRIEL PRIVATE LABEL Strut Assembly $39.79 Transmission-Automatic FRAM Filter Kit $5.77 Wiper & Washer ACDELCO Wiper Blade $4.19 Link to comment Share on other sites More sharing options...
