McDave Posted June 29, 2008 Share Posted June 29, 2008 While replacing the front speakers and wiring in a cd changer, I noticed the factory dash unit had enough wires coming out of it so that some of them must be for rear speakers. If so, where are they headed? Are the rear doors pre-wired, or do the wires head to the back of the car, or do they stop short under the dash somewhere? I need some more bass and since there isn't enough room in the car for my Bazooka, I'm thinking of installing some 6x9's. Where would you install them? Rear doors, rear pillars, rear inner wheel wells, or other? Dave Link to comment Share on other sites More sharing options...
The Dude Abides Posted June 29, 2008 Share Posted June 29, 2008 Dave Since you have a later model gl i believe the speakers go to the rear doors but there hardly base makeing material. only bout the 6 1/2 at the biggest. lotts of people put in a sub box but its exposed to anyone who walks buy and sees it. You might be able to custom make a box and fit it into the rear tool box area. I havent seen people put speakers in most of the places your talking about. the previous owner of mine had some installed in the rear hatch. It didnt weigh them down to much. Im fixing my interior so i havent gotten around to reinstalling the speakers but im sure itll sound great. Ben Link to comment Share on other sites More sharing options...
Andy FitzGibbon Posted June 29, 2008 Share Posted June 29, 2008 The rear doors in GLs and GL10s had speakers (not sure about DLs). When the EA82 body style changed over to the Loyale model name in 1990 the rear door speakers were eliminated, along with some other interior features, to make the line cheaper. Andy Link to comment Share on other sites More sharing options...
dhise Posted June 29, 2008 Share Posted June 29, 2008 I've been really happy with one of those kenwood under-the-seat style subwoofers. I was just looking to fill out the sound and not rattle the license plate off. Picked up a used one on ebay for cheap and the stereo sounds 100% better than it did with just the door speakers. Link to comment Share on other sites More sharing options...
McDave Posted June 30, 2008 Author Share Posted June 30, 2008 Hey thanks for the suggestions guys! I hadn't thought about the rear hatch. I pulled the cover off it and there's plenty of room for some 6 x 9s. I may even be able to hide them behind the existing vents in the panel. I had forgotten about the compact powered subwoofers, dhise. I used to have one on a car long gone. Wish I still had it now. Will be on the lookout for a cheap one. Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted June 30, 2008 Share Posted June 30, 2008 why not just use the cargo cover to cover the sub thats what i did on my 91 loyale and i used one of the low profile subs in my brat those things are pretty good Link to comment Share on other sites More sharing options...
McDave Posted June 30, 2008 Author Share Posted June 30, 2008 Quote why not just use the cargo cover to cover the sub thats what i did on my 91 loyale and i used one of the low profile subs in my brat those things are pretty good Right now I need all the floor space for my bike' date=' camping gear, air mattress, ect, and once hunting season gets here I'll be hiding my guns and gear under the cargo cover. Besides, I'm not [u']that[/u] much of an audiophile. The 6 x 9s may be enough for me (and cheaper). Link to comment Share on other sites More sharing options...
Gloyale Posted June 30, 2008 Share Posted June 30, 2008 Just be aware that the factroy wiring uses a common grounding for the front and rear speakers on each side. So if you use an aftermarket deck you will need to run new wires to seperate them. I find it easier to run new wires to the fronts. There are pink 2 wire connectors at each kick panel. run you're new front speaker line to those connectors, rather than all the way into the doors. The rear speaker harness should be under the trim plastic at the *B* pillar. hook you're new rear speakers to them. Link to comment Share on other sites More sharing options...
McDave Posted June 30, 2008 Author Share Posted June 30, 2008 Thanks Gloyale! Thank will save me some searching for the wires. and head scratching should I ever decide to change out the head unit. Link to comment Share on other sites More sharing options...
Davalos Posted June 30, 2008 Share Posted June 30, 2008 I did mine in the rear doors also. I was considering doing some larger ones in the rear tailgate - if you pull the plastic panel you will find you have enough room for that. You will probably get some rattle there, tho. I can't imagine no one has thought of that before. This is what I did, if that helps. Same speakers in the front & rear. It really does sound pretty good. I'm not gonna win any competitions or anything, but it's very respectable. The headunit WILL need an extension sleeve, and it'll be weird to get used to. They make lots of 1. DIN stuff out there. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted July 1, 2008 Share Posted July 1, 2008 Also consider that depending on how much weight you add to the rear hatch, the shocks may not be able to hold it up anymore. Rockauto.com had new shocks for $20 each, which would probably work better than the 20 year old ones. -Dave Link to comment Share on other sites More sharing options...
