quick question
The Scooby
ok i just picked up some pugs in 15's, and put some wildcat 215/75/15's on it, took a salzall to the front fenders and did soem beating, now they clean no problem.
but when going into full articulation the rears dont clear the fenders. this is a 85 wagon and the rear shocks are at their lowest height setting. now when i put them to the tallest setting i should be fine right? in theory i really only need 1inch of clearance and a BFH will do the rest, but what is the gain when going from lowest to heighest setting on those shocks?
Thanks
brake lines are good until over a 4inch lift?
4 inch?
Rear lines will be OK if you release them from the rear swing arms with a 4" lift.
Front lines you really should lengthen. They are OK for highway .... but stretch very tight at full articulation offroad.
