4wd light stays on....
probably a sensor/switch, stuck or broke. pull out the ebrake cover and console, you will see a switch with a black and red wire next to the 4wd selector. thats is most likely the problem, either it is stuck, not disengaging the switch....cracked in half due to the way plastic gets brittle.
i will have that checked out tomorrow. it's at my bf's shop so i'll tell him. Thank you :)
