Now with starting problems!
So here is the deal, just a click and and low juice on the battery. The situation; New battery yesterday wouldn't hold juice, new starter contacts, side by side starter pushbutton with ignition, problem persists, was more intermittent than it is now. Is there a voltage regulator? where? Is some other part of the starter fail-able like that? I got 14. 2 at the alt. 14.1 at the battery. Any other way to test the alt? I hate throwing money away but I might just to get a new starter and alt(right before I drop in a ej, darnit:banghead: ea81, 82' GL
Check the spade connector for the solenoid. Likely you'll need to replace it.
It does seem a little corroded. Sometimes, now, it doesn't click. The starter is about 5yrs old. Is it just getting time? I'll check the spade connector.
It could also be a bad connection at the ign connection plug under the dash. Its a pink connector to the right of the steering column and under the dash cover. I've seen these have melted plugs before when the contacts are loose.
Well I already have a dead ignition switch and now a pushbutton connected right at the pink connector. But, I have an update. After starting four times today like nothing was wrong but the sound of a bad gear and not starting twice and having to get a push to start (just to start fine at the next stop) I spent the cash on a remanufactured starter for a 87 automatic, it starts like a jet. It was $95 with a 2yr warranty and the old one was a bosch. The guy said the bosch ones are crap and wear fast. Both were for an 87 auto. The bosch cost me $150 5yrs ago. Thanks for the help, if its something else, still.....:horse: ....!
