Uberoo Posted July 5, 2008 Share Posted July 5, 2008 my justy just siezed its motor.it has close to a full tank of gas.What is the best way to empty it? Link to comment Share on other sites More sharing options...
idosubaru Posted July 5, 2008 Share Posted July 5, 2008 pull the fuel pump outlet and give 12 volts to the fuel pump. Link to comment Share on other sites More sharing options...
idosubaru Posted July 5, 2008 Share Posted July 5, 2008 on most subaru's (i'm not familiar with justy's) when the ECU is set to diagnostic mode and the key is turned - it cycles the fuel pump on once every second and gives a solid squirt of fuel. so if you wanted to do this the easy way on one of those, you would just pull the fuel pump outlet or pull it past the fuel filter (then it's getting filtered!?!) - and turn the key on (green connectors connected for diagnostic mode). all you'd need is a knife (to cut the hose). if it's carbed this won't be a possibility. finding the fuel pump relay is another option if you know where that is. Link to comment Share on other sites More sharing options...
Uberoo Posted July 5, 2008 Author Share Posted July 5, 2008 I just hotwired the pump to 12V.I got 6.5-7 gallons out... Link to comment Share on other sites More sharing options...
Phizinza Posted July 6, 2008 Share Posted July 6, 2008 Spike the tank and catch with a tub... easy :-p Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted July 6, 2008 Share Posted July 6, 2008 Spike the tank and catch with a tub... easy :-p Link to comment Share on other sites More sharing options...
