Fairtax4me Posted November 1, 2015 Share Posted November 1, 2015 Pull/push the input shaft. Any play in/out means the mainshaft bearing is bad. There is some up/down play normally. I would say about 1mm is what I normally find on these. Link to comment Share on other sites More sharing options...
gts24 Posted July 24, 2016 Share Posted July 24, 2016 (edited) So, Gloyale, I just did this "fix" here: http://forums.nasioc.com/forums/showthread.php?p=37195297#post37195297 for my Subaru WRX Wagon 5MT. And now I can't select any gears (while the car isnt' running of course) Did we simply not get the shift fork aligned properly? We started with the car in neutral, but a helper of mine moved it around "playing with gears". Does the transmission need to be in neutral for re-assembly? Do we simply need to "line up" the 3 shifter rails? Do you have a picture of how that should look? Any help you can offer is greatly appreciated. Does anyone have a picture of the "3 shifter rails" and how they are supposed to be properly lined up? thanks, Edited July 24, 2016 by gts24 Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 24, 2016 Share Posted July 24, 2016 The first post in this thread, 5th picture, shows the shift rail forks. They should all be in line in their center positions. Link to comment Share on other sites More sharing options...
gts24 Posted July 24, 2016 Share Posted July 24, 2016 On 7/24/2016 at 2:17 PM, Fairtax4me said: The first post in this thread, 5th picture, shows the shift rail forks. They should all be in line in their center positions. Thank you for your reply. Before I saw this, we already had just sealed the transmission back up.... AGAIN, after lining them all up in exactly that fashion. You confirmed it. Link to comment Share on other sites More sharing options...
