Get a clear 3/8 plastic line. You can pull the bottom radiator trany hose, to flush the radiator cooler as well. Put the line from the radiator into a gallon jug (see through).
Drain, then fill the transmission with new fluid. Start the engine, let a couple of quarts pump out. Stop the enging and refil the trans. Keep doing this until clean new fluid comes out.
If your quick or have help, you can shift the trans through all the gears while its running and keep on filling the trans as the same rate as the old fluid is coming out.
Just don't run the trans out of fluid.
Thanks Imdew, Thats what I intend to do. Except I'm using a 5 gallon pickle bucket and a gallon bottle of ATF. I'm have a torque bind issue with the car and I'm hoping a good flush will help. I'm going to need to use the car soon so I want to get this done. Thanks again.
