I have a 96 Legacy Sedan and I need to know what size the rotor is.
Replacing the rotors & pads etc. 231 --277 --0r 260
I found them at Autozone unless someone can suggest an alternate place & pricing...
Thanks
there was a very informative post a while ago here by a guy i believe by the name jamal......anyways according to his post your rotors should be the 260x22mm size.... also not sure if you have NAPA out there but i buy alot of parts from them and so far they have held up pretty well.....
might make a difference what legacy sedan you have. some models have the EJ22 (like L) and others have an EJ25 (like LSi and GT).
but yes - that post by jamal is EXCELLENT and will probably answer all your lifes questions about subaru brakes. i'd do some searching to find it or links to it at NASIOC.
