jonas Posted July 18, 2008 Share Posted July 18, 2008 running 15's on my '85 brat. just wondering what you guys do to get the speedometer to read accurately, or do you even care? i'm fairly accurate (followed the woman around at various speeds, and just go with traffic) just guessing my speed, but i like things to be working correctly, needed or not. the little things tend to drive me nuts. Quote Link to comment Share on other sites More sharing options...
nw_david Posted July 18, 2008 Share Posted July 18, 2008 im running 15's too, i just looked up a calculator for specific speeds, like when my spedo hits 75mph im really going 90mph i compared my 205/65/15's to 170/70/13 (i think thats a close enough size) http://home.netcom.com/~sgalaba/tiresize.htm Quote Link to comment Share on other sites More sharing options...
idosubaru Posted July 18, 2008 Share Posted July 18, 2008 speedometers aren't very consistent. i've actually had a number of subaru's that have a MORE accurate speedometer when i increase the tire size. so i wouldn't rely on the tire size calculators for those. best to carefully manage mile markers on a very long road trip or borrow someone's GPS. - mine have varied from 0% - 10% when i increased tire size, but the tire size calculator didn't necessarily predict it correctly. for the highways - you'll notice going 105 miles instead of 100 - that would be about 5% off. meaning when you're speedo shows 50 you're actually going 52.5. do that a couple times and you'll narrow down the percent Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted July 18, 2008 Share Posted July 18, 2008 I think mine shows about 47 or so with my 205/75/15 and that equals about 55. too soon to tell tho for sure. just overlay some stickers over the speedo face for correction lol Quote Link to comment Share on other sites More sharing options...
jonas Posted July 18, 2008 Author Share Posted July 18, 2008 well, my speedometer bounces all over the place. really want to replace the cable 'cause it bugs the ************ outta me. now if i can't get it to read accurate, why bother i'm wondering. is there a certain gear/cable i can get to compensate for the tire size? Quote Link to comment Share on other sites More sharing options...
TeamCF Posted July 18, 2008 Share Posted July 18, 2008 is there a certain gear/cable i can get to compensate for the tire size? I know you can get kits for more popular rigs to adjust the "transmission to speedo" ratio after changing tire size. (or some people just change out the diff grear ratios) But as for Subarus.... we are part of only a small percentage that put bigger tires on them. So Proly no off the shelf fix for it. Could be a cable out of another model that might do the trick. But I don't know for sure. Quote Link to comment Share on other sites More sharing options...
ahole Posted July 19, 2008 Share Posted July 19, 2008 I run 225/75R14's on my Loyale (26.8") and it's an easy-to-calcuate 10% slow on the speedo. It was 2.5-5% fast from the factory, which means that I don't really have 148,000 on the clock. It's closer to 141,000:banana: WHEEEEEEEE! Quote Link to comment Share on other sites More sharing options...
Gloyale Posted July 19, 2008 Share Posted July 19, 2008 I have a cool Radar Detector/Jammer that also has GPS and can use the GPS to tell you you're speed. I tested my GL Turbo running 27x8.50/14s and I was about 10% faster than indicated speed. 20=22 30=33 40=44 50=55 70=77 Quote Link to comment Share on other sites More sharing options...
edrach Posted July 20, 2008 Share Posted July 20, 2008 http://www.miata.net/garage/tirecalc.html Quote Link to comment Share on other sites More sharing options...
nw_david Posted July 21, 2008 Share Posted July 21, 2008 http://www.miata.net/garage/tirecalc.html thats a really good one Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted July 21, 2008 Share Posted July 21, 2008 with my 31's, when my speedo shows 55, Im doing about 70. its more accurate at lower speeds. Quote Link to comment Share on other sites More sharing options...
lonnie Posted September 16, 2008 Share Posted September 16, 2008 today put 195.70.13 on my 85 brat. believe speedo will probably read 7% slow assuming stock tire at 165.70.13. does this sound right and is that the original tire size? ps-do notice a significant improvement in ride quality on the road. Quote Link to comment Share on other sites More sharing options...
Greenley Posted September 16, 2008 Share Posted September 16, 2008 assuming stock tire at 165.70.13. does this sound right and is that the original tire size? On my '84 & '86 4wd ea81's, the stock tire size is a 185/70/13. I'm sure your brat is the same. Quote Link to comment Share on other sites More sharing options...
Phizinza Posted September 16, 2008 Share Posted September 16, 2008 I used my GPS to figure out what speed was RPM on my tacho in top gear. As I usually always cruised in 5th even in town. The tacho never lied I found. MY speedo was bouncy and all over the place anyhow. Changed everyday. Quote Link to comment Share on other sites More sharing options...
