lostinthe202 Posted July 22, 2008 Share Posted July 22, 2008 '96 OBW 182k My recirculate button sticks. I never use it but every few weeks the wife borrows my car and she does use it. After she's pressed it, I depress it, but it takes usually 2-3 days before it will pop back out. I want to shoot some kind of lube in there to free it up, but I don't know what's back there. Is it an electrical switch or a mechanical one that activates a vacuum motor? I thought of maybe dry graphite powder, anyone have a similar experience they were able to work out? Thanks! Will- Quote Link to comment Share on other sites More sharing options...
Spiffy Posted July 22, 2008 Share Posted July 22, 2008 sounds like the usual spilled beverage issue... isopropyl alcohol will help free things up... warm water also works but doesn't evaporate as well... I'm still trying to get my vents and cup holder to work smoothly on my forester... --Spiffy Quote Link to comment Share on other sites More sharing options...
lostinthe202 Posted July 22, 2008 Author Share Posted July 22, 2008 Excellent, thanks for the tip, I'll squirt some in when I get home. I've actually got some here at work, but with my luck I'd get pulled over and have to breath into a thingy. Thanks! Will- Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted July 23, 2008 Share Posted July 23, 2008 I have had good luck using Windex and paper towels. Just squirt, and start wiping. Quote Link to comment Share on other sites More sharing options...
Gnuman Posted July 23, 2008 Share Posted July 23, 2008 Am I the only one here that goes straight to "take the thing loose from teh dash and clean it properly"? < G > If you search under "Climate control backlight" you will find several threads with instructions on how to take that part of your car apart, and put it back together again. While it is apart, you will find it much easier to clean it real well and have it working for a good long time. If you "just squirt some stuff in there", the gunk that is gumming the works up will still be there, and will cause you problems again. Just my $.02. . . Quote Link to comment Share on other sites More sharing options...
lostinthe202 Posted July 23, 2008 Author Share Posted July 23, 2008 Am I the only one here that goes straight to "take the thing loose from teh dash and clean it properly"? Right you are, and my backlights are out so I plan on doing this, but I'm currently working 12 hour days with a 3 hour there-and-back commute and will have this schedule for the rest of the year at least, and what free time I've got for auto repairs will will go to a clutch job that takes priority so if I can squirt some stuff in there and loosen things up for awhile I'm happy to take that route. Quote Link to comment Share on other sites More sharing options...
Spiffy Posted July 23, 2008 Share Posted July 23, 2008 take the thing loose from teh dash and clean it properly that would be ideal, if it weren't so sticky that you can't get it out... that's the issue I have... I have to squirt stuff in there to get it loose enough to remove so that it can be properly cleaned... --Spiffy Quote Link to comment Share on other sites More sharing options...
