Grounded lead or bad guage?
Symptoms: 1985 Brat - Oil pressure dash guage reads near 75 psi all the time, hot, cold, idling, normal driving, even when the engine is shut off.
Measures taken so far yielding no changes: completely rebuilt the oil pump (new o-rings, shimmed the spring, new mounting gasket, etc.)
Installed new sending unit.
Most likely culprit is....................._______________?
If its the wire lead wear are they prone to have problems?
Disconnect the wire and see if it goes to zero.nipper
Disconnected it from the s/u. Guage stayed in same place, just below 75 psi. Sending unit is brand new NAPA.
Next place to look?
