mellow65 Posted July 25, 2008 Share Posted July 25, 2008 ok so i got from subaru that you can use pretty much any kind of lsd additive and it should work. But how much are you supposed to use? i know you are supposed add some more if the plates chatter, but what's a good starting point. Quote Link to comment Share on other sites More sharing options...
subyrally Posted July 25, 2008 Share Posted July 25, 2008 hmmm, this is a good question. the stuff ive seen usually just says to add the contents of the tube it comes in to the diff when you refill it. but im not sure on a subaru rear diff. Quote Link to comment Share on other sites More sharing options...
Turbone Posted July 25, 2008 Share Posted July 25, 2008 I would assume its just like any other diff. Fill it to the bottom of the filler hole. Quote Link to comment Share on other sites More sharing options...
mellow65 Posted July 25, 2008 Author Share Posted July 25, 2008 I would assume its just like any other diff. Fill it to the bottom of the filler hole. no i'm talking about the additive not the gear oil with additive added. you get little bottles of friction modifier (lsd fluid) and add in with normal oil. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted July 25, 2008 Share Posted July 25, 2008 think it was lucas makes diff oil that is compatible with lsd dffs. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 25, 2008 Share Posted July 25, 2008 The additive i bought said to use a full tube and top off with gear oil. So I did. Quote Link to comment Share on other sites More sharing options...
Spiffy Posted July 25, 2008 Share Posted July 25, 2008 The additive i bought said to use a full tube and top off with gear oil. So I did. same here, only it was for big american trucks, or at least that's what they listed on the bottle... I figured my diff was a lot smaller and used half the bottle... I suppose the best way to find out is to call subaru and find out how many ounces are in their bottle of friction modifier... --Spiffy Quote Link to comment Share on other sites More sharing options...
Turbone Posted July 25, 2008 Share Posted July 25, 2008 no i'm talking about the additive not the gear oil with additive added. you get little bottles of friction modifier (lsd fluid) and add in with normal oil. Ahhh, ok. Never used it, I dont have a clue, sorry :-\ Quote Link to comment Share on other sites More sharing options...
mellow65 Posted July 25, 2008 Author Share Posted July 25, 2008 well after i got off the phone with lithia they said they don't have the additive any more and the only way was to get that kind of fluid was to get the 5 gallon special subaru LSD gear oil. um yeah no thanks. called a couple more subaru places and found one that said they get thier stuff from GM and the bottle is 4oz. so now we know and knowings half the battle. GI JOE!!!! Quote Link to comment Share on other sites More sharing options...
mellow65 Posted July 25, 2008 Author Share Posted July 25, 2008 called chevy they have the 4oz bottle for $9.95 looks like i'm off to chevy. thanks guys Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted July 25, 2008 Share Posted July 25, 2008 If I remember correctly, I just dumped the whole 4 oz. tube in the diff then topped it off with gear oil. Quote Link to comment Share on other sites More sharing options...
mellow65 Posted July 25, 2008 Author Share Posted July 25, 2008 If I remember correctly, I just dumped the whole 4 oz. tube in the diff then topped it off with gear oil. and that's how i'm going to do it, i just was looking for that magical "4oz" amount. Quote Link to comment Share on other sites More sharing options...
soobscript Posted July 26, 2008 Share Posted July 26, 2008 FWIW, I filled my 200k mile RX diff with AMSOIL 75W-90 gear oil only and have had no issues or chatter and perfect operation with over 40k miles and plenty of off-roading, launches, and other abuse. Quote Link to comment Share on other sites More sharing options...
mellow65 Posted July 26, 2008 Author Share Posted July 26, 2008 FWIW, I filled my 200k mile RX diff with AMSOIL 75W-90 gear oil only and have had no issues or chatter and perfect operation with over 40k miles and plenty of off-roading, launches, and other abuse. i have heard good things about amsoil, it seems the people that use it really like it but i have never had a chance to use it yet. i like redline, and really because it got rid of so many grinds in multiple trannys. until redline lets me down for what ever reason, i can't see me going through different brands just to see, not unless it is way cheaper. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted September 16, 2008 Share Posted September 16, 2008 Which grades are you using to resurect worn trannys? Quote Link to comment Share on other sites More sharing options...
mellow65 Posted September 16, 2008 Author Share Posted September 16, 2008 Which grades are you using to resurect worn trannys? the red line 75/90 NS. make sure you get the NS because it doesn't have any friction modifiers added to it. If you read about it on their website it makes kind of makes sense about the lack of friction modifiers helping the synchros come to speed faster. i figured there was one way of calling their BS was to try it. and i must say in every tranny i have used it in, shifting was much better and took away a second gear grind on multiple trannys. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted September 17, 2008 Share Posted September 17, 2008 Ive seen cans around my dealer before that are made for 1 drain and fill of the rear diff. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 17, 2008 Share Posted September 17, 2008 FWIW, I filled my 200k mile RX diff with AMSOIL 75W-90 gear oil only and have had no issues or chatter and perfect operation with over 40k miles and plenty of off-roading, launches, and other abuse.is it possible your clutches are warn and that's why the fluid didn't make much difference? i've heard they do wear and have always wondered how much, how to check and how to rebuild. i have heard of people rebuilding them...or adding shims or whatever to bring the grip back up to spec's. Quote Link to comment Share on other sites More sharing options...
soobscript Posted September 18, 2008 Share Posted September 18, 2008 is it possible your clutches are warn and that's why the fluid didn't make much difference? i've heard they do wear and have always wondered how much, how to check and how to rebuild. i have heard of people rebuilding them...or adding shims or whatever to bring the grip back up to spec's. All I know for sure is that it still works. Quote Link to comment Share on other sites More sharing options...
