Rainy Posted July 27, 2008 Share Posted July 27, 2008 My power door lock switches do nothing. The fuse is good. Before I attempt to explore and tear things up, are there any tips I might consider? Is there a relay for this, and where is it? All the locks work fine manually. There are power switches on driver's and passenger's armrests, none in back. Thanks Link to comment Share on other sites More sharing options...
Cougar Posted July 27, 2008 Share Posted July 27, 2008 You didn't state if you have keyless entry or not and if so, is it working? Regardless, there should be a module behind the glove box that handles the control of the locks. It looks like fuse #3 supplies power to it. Link to comment Share on other sites More sharing options...
Rainy Posted July 27, 2008 Author Share Posted July 27, 2008 You didn't state if you have keyless entry or not and if so, is it working? Regardless, there should be a module behind the glove box that handles the control of the locks. It looks like fuse #3 supplies power to it. Thanks. I don't have keyless. Fuse #3 is good, I even swapped it out. I will look behind the glovebox next. Link to comment Share on other sites More sharing options...
