mine need some adjustment...
there is more pressure coming out of one hole than the other... there are two holes in each nozzle. the left nozzle works fine. the right nozzle, the far hole shoots out with more pressure. how can i adjust it to be equal and aim higher on the windshield?
I have never tried this on a Subie, but when this would occur on my old VW, I would use a needle or shirt pin to clean out the nozzle hole. Both are rather small in diameter. Just insert the needle or pin a few times in the nozzle would clean out the built up crud. Test the squirter for improved performance, reclean if needed.
