OK, I have a VW trike in which I blew the motor. Entirely my fault, a too fast timing adjustment while on a 700 mile trip which turned into a nightmare tow home at midnight and later. Actually I had problems the entire weekend but that's my life. *grin* Fun tho!
So after some research I'm going to be dropping a 2.2L into it. Most are from Impreza's. Tranny is no problem, there is an adapter to bolt it in with. The intake will be changed from efi to carb most likely by Scott of Bellingham.
But I need to know the cooling/heat range of the motor to plan to cooling system. What range does the motor like? What temp is overheat on those motors?
Sarge
Normal range is 70-90 degrees centigrade. (x0.5555+32 to get degrees F, isn't it?)
Overheating...hmm...difficult to answer accurately. The temp gauges in the cars engine comes from "lie", they indicate at just below 50% of the scale for the range 70-90. So, cruising along, you cannot be sure if the temp is 75, 78, or 90...it's just "normal".
There is 40% travel until the dial shows red/overheating/no go zone.
My money says that anywhere over 100 is overheating, 110 would give me sleepness nights, and 120+ would blow head gaskets and from there on the heads are warping.
Does that answer your questions at all :confused:
The Subaru cooling system has around 6.5 liters of coolant. The block itself swallows about two liters, the hoses, pump, cabin heater matrix, and overflow tank take the rest.
The t-stat is 190 degrees if i remeber correctly, that will be your target temp. i have seen my 2.2 (not blu) run up to 220 (scangauge) in the hot high plains, and have it barely show on the needle. i would say 220 is the upper edge of a comfort zone, as you do need some reserve for low coolant, flow issues , and extreemly hot air. at 260 i would consider that dangerous (even though its prbbly 2.3 of the gauge, but its amazing how quickly the gauge can climb from that point)
Give me a year (ballpark) for a 2.2 and i can give you more detailed information for designing a cooling system for the car.
nipper
*grin* It helped even tho I cheated and used the net to do the conversions. Math and don't get along.
Sarge
More info then you would ever want from the FSM:
Cooling system
Electric fan + Forced engine coolant circulation
system
Total engine coolant capacity (US qt, Imp qt) Approx. 6.1 (6.4, 5.4)
Engine coolant pump
Type Centrifugal impeller type
Discharge performance I
Discharge 20 (5.3 US gal, 4.4 Imp gal)/min.
Pump speed—total engine coolant head
760 rpm — 0.3 mAq (1.0 ftAq)
Engine coolant temperature 85°C (185°F)
Discharge performance II
Discharge 100 (26.4 US gal, 22.0 Imp gal)/min.
3,000 rpm — 5.0 mAq (16.4 ftAq)
Discharge performance III
Discharge 200 (52.8 US gal, 44.0 Imp gal)/min.
6,000 rpm — 23.0 mAq (75.5 ftAq)
Impeller diameter 76 mm (2.99 in)
Number of impeller vanes 8
Pump pulley diameter 60 mm (2.36 in)
Thermostat
Type Wax pellet type
Starts to open 76 — 80°C (169 — 176°F)
Fully opened 91°C (196°F)
Valve lift 9.0 mm (0.354 in) or more
Valve bore 35 mm (1.38 in)
Radiator fan
Motor 120 W
Fan diameter x Blade 320 mm (12.60 in) x 5
Radiator
Type Cross flow, pressure type
Core dimensions
670 x 361 x 16 mm
(26.38 x 14.21 x 0.63 in)
Pressure range in which cap valve is open
Above: 88±10 kPa
(0.9±0.1 kg/cm2, 12.8±1.4 psi)
Below: −4.9 to −9.8 kPa
(−0.05 to −0.1 kg/cm2, −0.7 to −1.4 psi)
Fins Corrugated fin type
Reservoir
tank
Capacity 0.5 (0.5 US qt, 0.4 Imp qt)
whle we're on the the subject, i know the recommended mix is 50/50, but is 66/34, antifreeze to water, better or worse for cooling.?
are there any conditions where more than 50/50 is desirable??
in milder climates, nevere below 0'F, is less antifreeze ok?
just wondering.
http://www.peakantifreeze.com/images/art_protection_chart_06.gif
If you live in the artic, upper north dakota (canada) or the equator, other mixes are desirable.
Get over 70% mix and you will start loosing the ability to carry heat away from the engine very quickly.
50/50 mix is best for most drivers, as it is the most cost effective.
nipper
nipper
Learned this one the hard way. Coulda swore I bought premixed once and filled the system with nutin' but antifreeze. Boiled over in less than 5 mins.
Sarge
Here in Montreal, very cold winters and hot summers and 60% seems to do the trick summer and winter. Never had the coolant freeze or boil nor had the temp needle higher than normal.
If you will never see freezing temperatures, a 20% anti-freeze would be good. Going weaker you will start to lose the lubrication and anti-corrosion properties that the anti-freeze additives provide.
Water is the best coolant. It has twice the heat capacity of anti-freeze (gylcol anyway) and can transfer heat twice as fast. In the textbooks.
In the real world, you must have something to break the water's surface tension and lube your pump, and stop corrosion.
