davebugs Posted August 1, 2008 Share Posted August 1, 2008 o.k. I forget if I found this info here or in the electronic copy of the FSM but I can't find it tonight and I need it. I have a 97 OBW with the P0740 & sometimes P0743 codes. Points to Solenoid B. I'm also parting out a 99 OBW and was gonna swipe solenoid B. But I can't find the pic that shows which one it is. I had found a nice black & white pic but I can't find it now. An easy to read diagram would also work. I'm not bright enought to read a real electrical diagram. All I have remaining to take off this car is the Duty B solenoid and the fuel sending units and it's outta here. Thanks for any assistance. Dave Link to comment Share on other sites More sharing options...
nipper Posted August 1, 2008 Share Posted August 1, 2008 http://www.endwrench.com/archive/sysdrive.html maybe there? nipper Link to comment Share on other sites More sharing options...
davebugs Posted August 1, 2008 Author Share Posted August 1, 2008 Thanks. Not what I had found before but I found something that might work in one of those articles. Hard to tell since it's such a closeup pic. What I had found before was a pic after the pan was removed. It labeled all the solenoids around the edge, etc. Tomorrow I'll look at the car after reviewing the Endwrench pic again. The pan is already off. Appreciate the assistance. Dave Link to comment Share on other sites More sharing options...
nipper Posted August 1, 2008 Share Posted August 1, 2008 prvt me with your email i have it for a 1998 nipper Link to comment Share on other sites More sharing options...
sea#3 Posted August 1, 2008 Share Posted August 1, 2008 The transmission are not the same , the 97 is a 1st gen trany and the 99 is a 2nd gen trany ( spin on filter) The valve body are totally different Hope this helps SEA#3 99 legacy auto.pdfFetching info... 97 automatic -legacy.pdfFetching info... Link to comment Share on other sites More sharing options...
davebugs Posted August 1, 2008 Author Share Posted August 1, 2008 Bummer. Thanks. I'll put the pan back on and scrap the car. Link to comment Share on other sites More sharing options...
johnceggleston Posted August 1, 2008 Share Posted August 1, 2008 sea#3 said: The transmission are not the same , the 97 is a 1st gen trany and the 99 is a 2nd gen trany ( spin on filter)The valve body are totally different Hope this helps SEA#3 i don't know a lot about auto trans, but even if the valve body is different as you say, the duty b may be the same. especialliy if you are just swapping that part, which is way more work than i'd attempt. the duty c i swapped was a fairly simple electric device, i can't imagine they redesigned it just because they upgraded the trans, but maybe they did. the trick would be getting part numbers to compare. Link to comment Share on other sites More sharing options...
davebugs Posted August 1, 2008 Author Share Posted August 1, 2008 Funny I was debating about the Duty C and rear clutch pack. Car has 200k and tranny was shot when it arrived so they aren't known good parts. I was thinking of doing it just to do it. But I have other stuff backing up. Infact I'm about to give up and drill holes in a good fuel tank since I just pulled the pumps. A tranny guy I use can get me a new correct (probably not Subaru but the part# listed for the 97) for under 100 bucks. I just had this 99 on the lift parting it out. Thanks for the help folks. Dave Link to comment Share on other sites More sharing options...
johnceggleston Posted August 1, 2008 Share Posted August 1, 2008 some of the early 99 auto trans are the same as the 97 - 98s. if it has the spin on external filter it is not compatable. if it doesn't have the filter , then it will work. Link to comment Share on other sites More sharing options...
davebugs Posted August 1, 2008 Author Share Posted August 1, 2008 Thanks. The 97 I'm not sure, but the 99 has a spin on filter and is the pricey JEBA trans. Dave Link to comment Share on other sites More sharing options...
