I see a lot of people with WRX seats in legacys. I have a 90 Legacy Wagon and I found some seats from a 2003 WRX wagon for $300 in excellent condition.
Will these fit my car? Are there any modifications that need to take place in order for them to fit?
Is this a good deal?
Thanks
Kimo
I just swapped the buckle. I did have to drill out a rivet but after that it fit on there and worked fine. The only problem was occasionally having to dig for the lap belt because I didn't stick on the plastic guide.
So do they bolt right in? Yeah it was 300 for the front and rear so it seemed like a decent deal. If they're in good shape. I'm not gonna buy them though. I need to locate a turbo 1st gen legacy first.
They will bolt right in although the Legacy only uses four of the 5 bolts that the WRX seats use; not a big deal. Also, make sure you swap the seatbelt retainers onto the WRX seats since your legacy belts won't lock onto the WRX retainers. Not a problem otherwise; rails fit just fine in the Legacy; I did our '91 that way and the seats are way more comfortable. I've seen fronts from a WRX go for anywhere from $100 to $300 or more. Frankly I wouldn't spend more than $200 unless they were absolutely perfect and exactly the right color match.
The main issue is the automatic seat belts.
Here's some pics of them in my Legacy
http://www.main.experiencetherave.com/subaru/images/legacywrxseats/
The ride height was actually very similar if not the same. The seats are a little wider. If I didn't have the auto belts, they'd be in there.
I used to have the choker belts in my '91. Found a Subaru wrecking yard in Canada and bought a set of Canadian belts of the right color and trim. Installed and working fine, but a bit ugly since the new trim wouldn't fit over the space where the auto rail was; and the old trim wouldn't work either. I lived with the ugly and enjoyed the freedom of decent belts.
I've been trying to get manual belts for a long while. The stupid 90-91 tan interior is what foils me every time....
This from dominical1:
Saltair Recycling
4142 Thicke Road
Ladysmith, B.C.
V9G-1X5
Tel: 888-991-9918
or 250-245-4175
Fax: 250-245-4109
contact people are Ed or Rob Potts
Spendy in price but knowledgeable and a good selection of parts
Looks like a price drop on the $300 seats:
http://seattle.craigslist.org/see/pts/785064314.html
Thanks
Kimo
Saltair Recycling
4142 Thicke Road
Ladysmith, B.C.
V9G-1X5
Tel: 888-991-9918
or 250-245-4175
Fax: 250-245-4109
Thanks Ed,
I'll try giving them a buzz
