'98 Impreza won't shift out of Park
quote=steve22l]and if brake lights ARE working?.....then what?
There still could be a fault with the brake light switch .If it has cruise control it is a 4 pole switch, 2 poles for the brake lights, 2 poles for the shift lock . you will have to check for continuity,
if it doesn't have cruise .Then you will have to take a look at the neutral safety switch on the side of the trany, it may have an open circuit
SEA#3
Glad i could help , Just a question do you have a trailrer hitch on this car?
and were you towing a trailer when it happened ?
If so you mat have a short in you trailer that blew the fuse .
If you don't have a hitch then you will have a problem with the wiring on that circuit
SEA#3
