opus Posted August 4, 2008 Share Posted August 4, 2008 Grey 88 DL- pros--given to me, rust free body, non electric cockpit cons-- hasnt run in 7 yrs, parts missing, FI White 86 GL- pros-- runs like a monster, carb'd. cons-- body starting to show its age. So, what do I do? I really need the D/R. Do I gut the 86 and swap it all to the 88? Are the compatible, GL/DL?? Link to comment Share on other sites More sharing options...
The Dude Abides Posted August 4, 2008 Share Posted August 4, 2008 you give me the dl i love dls Link to comment Share on other sites More sharing options...
The Beast I Drive Posted August 4, 2008 Share Posted August 4, 2008 I could really use the DL corner lights if youd be willing to part with them Link to comment Share on other sites More sharing options...
The Beast I Drive Posted August 4, 2008 Share Posted August 4, 2008 Oh and everything should swap over just fine, but the wiring for the motor could get tricky. Or you could keep it fuel injected and replace whatever parts are missing, just swap the manifold from the DL onto the GL motor when you swap the motor and tranny in Link to comment Share on other sites More sharing options...
Spiffy Posted August 4, 2008 Share Posted August 4, 2008 swap the dual range and radiator into the grey one... it should be an easy swap... get the FI running... --Spiffy Link to comment Share on other sites More sharing options...
baccaruda Posted August 4, 2008 Share Posted August 4, 2008 the FI block has a higher compression ratio than the carbed block. Link to comment Share on other sites More sharing options...
opus Posted August 4, 2008 Author Share Posted August 4, 2008 Would putting the carb setup on the '88 be easy enough? I would rather have carb'd than FI. I cant see how anything with that should be difficult. My 86 has only a couple wires and about 2 or 3 vacuum hoses on it. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 4, 2008 Share Posted August 4, 2008 Would putting the carb setup on the '88 be easy enough? I would rather have carb'd than FI. I cant see how anything with that should be difficult.My 86 has only a couple wires and about 2 or 3 vacuum hoses on it. You crazy? SPFI is far and away a better system. You would have to do a lot of rewireing and changing of the fuel system to do it. Not worth it to backtrack like that. GD Link to comment Share on other sites More sharing options...
opus Posted August 4, 2008 Author Share Posted August 4, 2008 Ok, thought it would be simple. This thing has been sitting for 7 years. Wasnt too sure I wanted to fuss around trying to get that running. I am not interested in all the codes that are going to pop up and all that goodness that goes with it. I do believe it has a bad fuel pump, but who knows beyond that. Not wanting to put money into another valueless rig....ya know? Link to comment Share on other sites More sharing options...
ahole Posted August 4, 2008 Share Posted August 4, 2008 I agree with spiffy. Spfi is sweet. carbs are inconsistant with elevation and weather and seasons. Plus you get a little more power. I used to like carbs too... until i owned a(n) FI car. Link to comment Share on other sites More sharing options...
opus Posted August 4, 2008 Author Share Posted August 4, 2008 I agree with spiffy. Spfi is sweet. carbs are inconsistant with elevation and weather and seasons. Plus you get a little more power. I used to like carbs too... until i owned a(n) FI car. .....you are driving the wrong rig if you are concerned about power. Link to comment Share on other sites More sharing options...
The Beast I Drive Posted August 4, 2008 Share Posted August 4, 2008 .....you are driving the wrong rig if you are concerned about power. lol Link to comment Share on other sites More sharing options...
opus Posted August 4, 2008 Author Share Posted August 4, 2008 Going to part it out and crush it. Too much work involved to fix it up. Link to comment Share on other sites More sharing options...
cameron 1 Posted August 5, 2008 Share Posted August 5, 2008 ya SPFL is the way to go when ur done u can use the white one as a tweek ramp ohya:headbang: Link to comment Share on other sites More sharing options...
ahole Posted August 5, 2008 Share Posted August 5, 2008 .....you are driving the wrong rig if you are concerned about power. Have you seen my vehicle list? Link to comment Share on other sites More sharing options...
The Beast I Drive Posted August 5, 2008 Share Posted August 5, 2008 So I get the side marker lights from the front right? how much do you want for em? Link to comment Share on other sites More sharing options...
opus Posted August 5, 2008 Author Share Posted August 5, 2008 So I get the side marker lights from the front right? how much do you want for em? Lets see....do I give it to you or put it on my wifes car? Sorry. :-\ Link to comment Share on other sites More sharing options...
