()__1337_CRAYOLA__()> Posted August 5, 2008 Share Posted August 5, 2008 Just did the intake gaskets and changed the oil (10-40) and when im cuising i got a cloud of blue smoke following me... this is a new occurence to me today what could cause this so suddenly... what should i check EA81 Weberized 210,000 miles 4 speed Link to comment Share on other sites More sharing options...
idosubaru Posted August 5, 2008 Share Posted August 5, 2008 not sure how the EA81's work but if the intake gaskets have the coolant passages like the EA82's - then usually tons of coolant gets in there. but BLUE definitely sounds like oil. vaccuum, carb, PCV checking time i would think (EA81 and carb idiot that i am talking). if it didn't do this before i wouldn't expect anything serious - just something mixed up. good luck! Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted August 5, 2008 Author Share Posted August 5, 2008 Just eliminated the PCV system pipe pluged the PCV spot and put breathers on the valve covers but it is still doing it im so confused maybe cause i dont have a cat im still burning the oil out of the muffler? all the plugs look perfect and its not running fat so i donno... Link to comment Share on other sites More sharing options...
zstalker Posted August 5, 2008 Share Posted August 5, 2008 you check your oil level? I don't want to doubt your abilities, but overfilling the sump can easily result in masive clouds of smoke following you Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted August 5, 2008 Author Share Posted August 5, 2008 it right at the full line on level surface lol Link to comment Share on other sites More sharing options...
NorthWet Posted August 5, 2008 Share Posted August 5, 2008 Are you sure that it is blue smoke and not steam? Again, not doubting abilities or power of observation, some questions just need to get asked. Steam will dissipate quickly in still air, smoke thins out only if diluted with more air. Does this occur while idling? Only during cruise? More so taking off from a stop after idling or after compression braking? Becomes thicker the more power you apply? My crystal ball says to bet that it is steam, and that the intake manifold gaskets aren't sealing the intake's water passage properly. (Yes, GG, EA81 and EA82 non/mfpi gaskets are the same/similar.) Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted August 6, 2008 Author Share Posted August 6, 2008 not steam cant smell coolant/ not losing any coolant it smells like burning oil and im sure its blue Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 6, 2008 Share Posted August 6, 2008 Lack of proper PCV routing is probably causing already poor valve stem seals to suck more oil than usual as you aren't actively pulling blow-by gasses from the crankcase as you should. Valve cover breather filters are NOT a substitute for a system to remove blow-by gasses. Before PCV valves we had the road draft tube system.... just venting the valve covers is not adequate. You see them on hot-rods..... but then those are the same folks that buy edelbrock carbs which are also an abomination.... don't emulate those guys. GD Link to comment Share on other sites More sharing options...
