EA81/EA82 Hybrid disty q's
Im in need of a good distributor on the Beast, it has an EA81 in it. I remember reading somewhere something about swapping the shaft from a EA81 disty and putting it in the body of an EA82 disty and utilizing the EA82 electronics. I have a practically new EA82 disty ( has like 500 miles) and a buch of bad EA81 units. From what I saw comparing them, looks like all that would have to happen would be swap the shaft and add a spacer and shim it till its right? and that only one of the 2 mounting tabs will be used. Any help is appreciated, thanks
Thank you, that was pretty much what i was looking for. One other thing, does anyone know the dimensions of the bushings pressed into the body of the EA81 distributors? Are they available from anyone?
They are availible, but unless you have machining capabilities you won't have good luck installing them. The old ones have to be reemed out and if it's not done perfectly straight you'll have major issues.
