can a newer stock cd radio be put in 94 legacy
Yeah I believe it will work. I'm not sure if the plugs are the same, but you can probably find a harness online to replace the newer stock harness and merge it with one of the adapter harnesses for the 94 Legacy.
Or you could maybe find a harness at a junkyard and snip it out.
if it's the single DIN style then it should work... I've swapped from '00 to '98 to '88 and back all using the same stock subaru harness...
but if it's one of the new fancy contoured stereos then probably not...
--Spiffy
