Loyale will not start: no fuel to engine
I have a 92 loyale 4wd with 160k miles. The last time I drove it was about 3 weeks ago and it worked fine. I went to drive it today and it wouldn't start. Engine cranks and there is spark. It appears there is no fuel getting to the engine, plugs are dry and don't smell like fuel. Any ideas where to start?
I don't think any of the fuses or fuesable links are bad. I don't hear the fuel pump when the ignition is on so maybe there?
Well....
I tried knocking on the fuel pump with the hammer and nothing happened. So i found the test light and there appears to be no power reaching the pump. The fuses are good and so are the fuesable links, I checked today. I guess I will start looking for other problems in the electrical system. Any suggestions on where to look?
The fuel pump relay is actually above the ecu next to the ignition relay on a Loyale, not in the bank of four relays above the fuse box. Someone posted a photo of the pair here a couple weeks ago.
Yeah - I can never remember exactly. It will be next to the big square brown one then - above the ECU. Most of the relays are around that general area near the drivers kick panel.
Thanks for the info. It appears there were 2 problems at once. No power to the pump and the pump needed to be whacked a few times. I fixed the power problem (bad connection at the pump) and pump still wouldn't run. I removed the pump to test it more easily than under the car hit it with the hammer handle a few time and it started working. I re-assembled everything than the car started up just fine.
