j2coe Posted August 7, 2008 Share Posted August 7, 2008 is there any way to tell what size an engine is? the car is a 2002 WRX and it is suposed to have a 2.0. the previous owner had a new engine put in when it died. I'm working out the various kinks. it is sluggish at low end, the turbo takes forever to kick in, and it occasionally gives a fule lean mix code. could it have ended up with a 2.5 from a later model and the ECU is not compensating well for the bigger engine? I think it just needs a lot more tweaking and the injectors cleaned ETC, but ... Link to comment Share on other sites More sharing options...
SubPar Posted August 7, 2008 Share Posted August 7, 2008 It'll say on top of the block. I think on the driver's side, if I remember correctly. EJ20 is 2.0, EJ25 is 2.5. Link to comment Share on other sites More sharing options...
j2coe Posted August 7, 2008 Author Share Posted August 7, 2008 thanks par. PITA to find under all the components, but it's the right engine. anyone seen anything on tuning the turbo? Link to comment Share on other sites More sharing options...
EVOthis Posted August 7, 2008 Share Posted August 7, 2008 i would hit up nasioc.com for tuning the stock turbo on the wrx.....alot of smart people on there and so much information..... Link to comment Share on other sites More sharing options...
