Front Strut Replacement on '99 OBW
It's time for new front struts on my '99 Outback Wagon. The car is a regular daily driver (no off-road, racing, etc.) and I'll be doing the work myself. Can anyone recommend a supplier and/or brand name of struts you've been happy with? Thanks
  Dickensheets said:
besides being 11 years old with 130,000 miles, what is a good indication of strut wear? I prob need them but ?????
Well, here's how Dragon failed on her rear pax strut:
Push on the hood/hatch/trunk hard. Car should bounce ONCE and stop. More bounces? Something's Bad.
Look at the car from all angles on a known FLAT surface. One side/corner/end lower or higher than the others? Not good.
Get under the car and look at the assemblies. Grease/wet spot on a strut? Bingo, we have a replacement coming.
As you can guess, I need a new rear strut. Not to hijack the thread, but is Subaru a car which needs a PAIR of struts when replacing, not just a single replacement on an axle?
