rguyver Posted August 13, 2008 Share Posted August 13, 2008 Along with the motor/ tranny adapters im also going to bring the weld in ring spacers for the rear brake EA EJ swap . 10$ for one set call dibs i have 5 sets see inner ring welded in then drilled to fit the older bolt pattern . Link to comment Share on other sites More sharing options...
Caboobaroo Posted August 13, 2008 Share Posted August 13, 2008 Can you do a set for a set of STi Brembos? I'm willing to pay extra for a set if you can. Link to comment Share on other sites More sharing options...
suberdave Posted August 13, 2008 Share Posted August 13, 2008 the rings you sent me a while back are to big. i hope these ones are smaller. the ID is right but the OD is to large for legacy backing plates. if they are i will call dibs on atleast one set if not two. -=Suberdave=- www.suberdave.com Link to comment Share on other sites More sharing options...
suberdave Posted August 13, 2008 Share Posted August 13, 2008 i think the set i have are for brimbo plates. ill bring them they may work. -=Suberdave=- http://www.suberdave.com Link to comment Share on other sites More sharing options...
Subarutex Posted August 13, 2008 Share Posted August 13, 2008 Dibs Link to comment Share on other sites More sharing options...
mellow65 Posted August 13, 2008 Share Posted August 13, 2008 so then with this and a xt6 5 lug hub i could have normal rear brakes on a ea82? Link to comment Share on other sites More sharing options...
Numbchux Posted August 13, 2008 Share Posted August 13, 2008 mellow65 said: so then with this and a xt6 5 lug hub i could have normal rear brakes on a ea82? yep, EJ r160 (the r180 backing plates are different...) rear brakes on an EA.... Link to comment Share on other sites More sharing options...
mellow65 Posted August 13, 2008 Share Posted August 13, 2008 Numbchux said: yep, EJ r160 (the r180 backing plates are different...) rear brakes on an EA.... nice :cool: Link to comment Share on other sites More sharing options...
s'ko Posted August 13, 2008 Share Posted August 13, 2008 will these be available after the show? After you weld it on, how what do you have to do to get the holes drilled. I assume that these are only beneficial if you have 5 lug rears. BW Link to comment Share on other sites More sharing options...
Pooparu Posted August 13, 2008 Share Posted August 13, 2008 I'll call dibs. thanks, earl Link to comment Share on other sites More sharing options...
rguyver Posted August 14, 2008 Author Share Posted August 14, 2008 Caboobaroo said: Can you do a set for a set of STi Brembos? I'm willing to pay extra for a set if you can. ya they must have different hub sizes for the sti and that is what i sent you ill have to measure some leg. rear hubs i thought they were all the same . how much were they out ? Link to comment Share on other sites More sharing options...
rguyver Posted August 14, 2008 Author Share Posted August 14, 2008 Caboobaroo said: Can you do a set for a set of STi Brembos? I'm willing to pay extra for a set if you can.thats what i am have i thought they were all the same ill have to do a re check . Link to comment Share on other sites More sharing options...
JWX Posted August 14, 2008 Share Posted August 14, 2008 I will buy a set and pay for shipping. Will you be building these after the show or is it a one time affair? Link to comment Share on other sites More sharing options...
suberdave Posted August 14, 2008 Share Posted August 14, 2008 rguyver said: ya they must have different hub sizes for the sti and that is what i sent you ill have to measure some leg. rear hubs i thought they were all the same . how much were they out ? like i said the ID was fine, the OD was close to 3/16" to large. -=Suberdave=- http://www.suberdave.com Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted August 14, 2008 Share Posted August 14, 2008 r160 backing plate info.. I'm still prototyping my zero weld version, but the design is more or less complete if anyone is interested I can post what I have so far. Until then this looks like a sure bet to get some ej stuff on the back of your ea car.... Kaz Link to comment Share on other sites More sharing options...
JWX Posted August 14, 2008 Share Posted August 14, 2008 Is that all you have so far? Link to comment Share on other sites More sharing options...
subyrally Posted August 14, 2008 Share Posted August 14, 2008 i could be interested in this, i am trying to get impreza RS rear brakes on my brat. im sure that one of the local shops could do it for me, but it would be nice to already have whats needed before i take it to a shop. Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted August 14, 2008 Share Posted August 14, 2008 no...I have the complete design.. but I am still fabricating the 1st prototype... Basically it is cutting the above two layouts out of 6mm aluminium and using another template to drill the ea holes in the ej backing plate and there you have it. I have it mostly cut out of the aluminium ( right side done left side almost done) but I still have to drill the ej backing plates and remove the ABS sensor mounts.. I'll update in a new thread when I have it finished and test fit on my car... Then I'll post instructions and full design documents so the community can replicate what I have done.. Kaz Link to comment Share on other sites More sharing options...
rguyver Posted August 14, 2008 Author Share Posted August 14, 2008 JWX said: I will buy a set and pay for shipping. Will you be building these after the show or is it a one time affair? looks like the ones i have are all for the brembos so i will make new ones in the smaller size and i will ship them . ill repost when i have the new ones made , thanks Link to comment Share on other sites More sharing options...
rguyver Posted August 14, 2008 Author Share Posted August 14, 2008 suberdave said: like i said the ID was fine, the OD was close to 3/16" to large. -=Suberdave=- www.suberdave.com sorry about that ill get you a new set in the smaller size no charge but it will have to be after the WCSS . Link to comment Share on other sites More sharing options...
JWX Posted August 15, 2008 Share Posted August 15, 2008 This is a very interesting thread. Link to comment Share on other sites More sharing options...
subyrally Posted August 15, 2008 Share Posted August 15, 2008 JWX said: This is a very interesting thread. Agreed Link to comment Share on other sites More sharing options...
Mykeys Toy Posted August 22, 2008 Share Posted August 22, 2008 I'm diggin it! too bad you cant just bolt in all the suspension goodies while we are at it..it would save a lot of time. R.G. Loved the hatch that thing launched like none other.. BTW what did you do to the fenders? use a roller? Really made the whole car look like a new design. Link to comment Share on other sites More sharing options...
rguyver Posted August 23, 2008 Author Share Posted August 23, 2008 Mykeys Toy said: I'm diggin it! too bad you cant just bolt in all the suspension goodies while we are at it..it would save a lot of time. R.G. Loved the hatch that thing launched like none other.. BTW what did you do to the fenders? use a roller? Really made the whole car look like a new design. I welded Dodge Omni fender flares on the rear the front is just a hack job . Im going to setup to make the smaller rings Monday so ill let you all know when they are finished . Link to comment Share on other sites More sharing options...
the_postie Posted August 30, 2008 Share Posted August 30, 2008 looky here 1 Link to comment Share on other sites More sharing options...
