opus Posted August 13, 2008 Share Posted August 13, 2008 Head gasket is leaking, 169K, Should he have it fixed it or sell it? I hear its a pricey endeavor. Link to comment Share on other sites More sharing options...
CNY_Dave Posted August 13, 2008 Share Posted August 13, 2008 1st case of a leaking H6 head gasket I've heard of, what's the confidence level its the head gasket? What kind of leak, and which way? Coolant out to the air, oil into the coolant, coolant into the cylinder, exhaust into the coolant, etc etc. Since you made it to 169Kmiles, I and the other H6 owners would love to hear what major work you had to do along the way- timing chain? water pump? etc. I have an '03 LLBean with about 80K. Dave Link to comment Share on other sites More sharing options...
opus Posted August 13, 2008 Author Share Posted August 13, 2008 Its not mine but they just did the valve cover gaskets and mechanic found coolant to air, underneath. I believe that is all that has been done with it. Owner crawled under and verified the leak, seepage only, right above the oil cooler. Link to comment Share on other sites More sharing options...
bheinen74 Posted August 13, 2008 Share Posted August 13, 2008 so the car overheats? and eats coolant? and the owner took it to shop where they replaced the valve cover gaskets? I am lost on this one Link to comment Share on other sites More sharing options...
opus Posted August 13, 2008 Author Share Posted August 13, 2008 No, its fine, nothing wrong. He saw the seepage and is now concerned. Link to comment Share on other sites More sharing options...
Suzam Posted August 13, 2008 Share Posted August 13, 2008 No, its fine, nothing wrong. He saw the seepage and is now concerned. Before I worry about replacing gaskets. I'd consider a can of the subaru "conditioner" recommended for the 2.5 engines. Link to comment Share on other sites More sharing options...
opus Posted August 13, 2008 Author Share Posted August 13, 2008 "conditioner"? Head gasket replacer in a can? Link to comment Share on other sites More sharing options...
2X2KOB Posted August 13, 2008 Share Posted August 13, 2008 Don't bother fixing it unless it gets a lot worse. You can buy a lot of antifreeze for what it would cost to fix it. And the stop-leak stuff just might work, too. Link to comment Share on other sites More sharing options...
CNY_Dave Posted August 13, 2008 Share Posted August 13, 2008 I concur with the earlier replies. Coolant-to-air only, seepage only, maybe add the magic gasket conditioner, and just watch it closely. A little anti-freeze seeping is not a big deal. It could seep the way it is for a long time- or get worse tomorrow, but I'd say chances are good it'll only seep for a good long while. Dave Link to comment Share on other sites More sharing options...
opus Posted August 14, 2008 Author Share Posted August 14, 2008 Excellent, will pass it on..thanks. Link to comment Share on other sites More sharing options...
