TeamCF Posted September 2, 2008 Share Posted September 2, 2008 OK. This pic prompts a question. See that little plug to the left (looking at it) of the crank pulley? What is that?! My engine has it too but it's not plugged into anything. Something Subaru put there as an evil plan to confuse me 20 some odd years later? Link to comment Share on other sites More sharing options...
scoobyclimbs Posted September 2, 2008 Author Share Posted September 2, 2008 OK.This pic prompts a question. See that little plug to the left (looking at it) of the crank pulley? What is that?! My engine has it too but it's not plugged into anything. Something Subaru put there as an evil plan to confuse me 20 some odd years later? It's a block heater...you can have my cord/plug..ya might need it being that your up in them thar hills... Link to comment Share on other sites More sharing options...
TeamCF Posted September 2, 2008 Share Posted September 2, 2008 It's a block heater...you can have my cord/plug..ya might need it being that your up in them thar hills... Ahhhhh. Link to comment Share on other sites More sharing options...
scoobyclimbs Posted September 3, 2008 Author Share Posted September 3, 2008 I surfaced the flywheel replaced the pilot, release bearings . I had to weld in the wear spots from the clutch fork on the release bearing housing ears. I order my parts : rear main seal, 180*thermistat, headgasket kit, ,oil pan gaskets,hatchback struts... Link to comment Share on other sites More sharing options...
TeamCF Posted September 4, 2008 Share Posted September 4, 2008 I had to weld in the wear spots from the clutch fork on the release bearing housing ears. How'ed you weld that? Looked like a casting to me and I know that welidng stuff like that wrong can just lead to a breakage. Mine had wear as well. I was afraid to mess with it and the welder though. So I left it alone. Link to comment Share on other sites More sharing options...
scoobyclimbs Posted September 4, 2008 Author Share Posted September 4, 2008 I had to weld in the wear spots from the clutch fork on the release bearing housing ears. How'ed you weld that? Looked like a casting to me and I know that welidng stuff like that wrong can just lead to a breakage. Mine had wear as well. I was afraid to mess with it and the welder though. So I left it alone. I just used the wire feed..you could just JB weld it and grind it down... The divits were so small ..hardly any added meterial...spot weld....There is not much too worry about really..I've welded cast many times with no issues..if it's small and not a huge peice no biggie.. Link to comment Share on other sites More sharing options...
TeamCF Posted September 4, 2008 Share Posted September 4, 2008 Well crap. Makes me wanna pull it all apart again.... not really. Link to comment Share on other sites More sharing options...
chazmataz Posted September 5, 2008 Share Posted September 5, 2008 thats a nice looking hatch you got there and at a very good price i might add. sounds about ready to take out to a trail and play. Link to comment Share on other sites More sharing options...
scoobyclimbs Posted September 5, 2008 Author Share Posted September 5, 2008 thats a nice looking hatch you got there and at a very good price i might add. sounds about ready to take out to a trail and play. Almost...I pressure washed the engine bay, trans, diff...+ the engine(removed). I should get my Rear main seal, clutch assembly ..in today and tommorrow I hope to find a blower motor @ u pullit.. I hope to be running by next week...hd gaskets, valve cover gaskets, oil pan gasket, cv boot, I need to find front brake hoses....any ideas Chaz..mine are 20" long I haven't had any luck..found 19",19.5" but no 20" Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 5, 2008 Share Posted September 5, 2008 Almost...I pressure washed the engine bay, trans, diff...+ the engine(removed). I should get my Rear main seal, clutch assembly ..in today and tommorrow I hope to find a blower motor @ u pullit.. I hope to be running by next week...hd gaskets, valve cover gaskets, oil pan gasket, cv boot, I need to find front brake hoses....any ideas Chaz..mine are 20" long I haven't had any luck..found 19",19.5" but no 20" get some a little longer will help when you do the lift Link to comment Share on other sites More sharing options...
Pooparu Posted September 5, 2008 Share Posted September 5, 2008 I hope to find a blower motor @ u pullit.. Last weekend I saw a couple of Gen 2's at the Foster U pull it. Link to comment Share on other sites More sharing options...
TheYeti Posted September 5, 2008 Share Posted September 5, 2008 Nice hatch! I would love to get my paws on those front mudflaps. j. Link to comment Share on other sites More sharing options...
scoobyclimbs Posted September 6, 2008 Author Share Posted September 6, 2008 I went to u-pullit today and scored a set of 14" pug steelies w/tires!!! also a good blower motor..and some hatch struts for team cf... Link to comment Share on other sites More sharing options...
scoobyclimbs Posted September 15, 2008 Author Share Posted September 15, 2008 (edited) since the site was down , I welded the rear diff. installed blower motor, replaced oil pan gasket, thermistat, hatch struts, front swaybar removal for max. articlutation, CV boot. SJR 4"lift is on it's way.. Edited September 16, 2008 by scoobyclimbs Link to comment Share on other sites More sharing options...
bratman18 Posted September 16, 2008 Share Posted September 16, 2008 since the site was down , I welded the rear diff. installed blower motor, replaced oil pan gasket, thermistat, hatch struts, CV boot. SJR 4"lift is on it's way.. Sweet:headbang: keep the pictures comin!!! Link to comment Share on other sites More sharing options...
michael appel Posted September 16, 2008 Share Posted September 16, 2008 I went to u-pullit today and scored a set of 14" pug steelies w/tires!!!also a good blower motor..and some hatch struts for team cf... Hey you left the spare under the pugeot do you want it Link to comment Share on other sites More sharing options...
scoobyclimbs Posted September 16, 2008 Author Share Posted September 16, 2008 Hey you left the spare under the pugeot do you want it Sure ...But is it a full size wheel? or a donut.. I had a wheel barrow full of parts/tools/4wheels/tires.. It took two trips to haul all the stuff I got that day...whew.. Link to comment Share on other sites More sharing options...
mcbrat Posted September 16, 2008 Share Posted September 16, 2008 I've seen 14" steels in 3 widths too. 5", 5.5" and 6" Link to comment Share on other sites More sharing options...
michael appel Posted September 16, 2008 Share Posted September 16, 2008 Sure ...But is it a full size wheel? or a donut..I had a wheel barrow full of parts/tools/4wheels/tires.. It took two trips to haul all the stuff I got that day...whew.. full size Link to comment Share on other sites More sharing options...
TeamCF Posted September 17, 2008 Share Posted September 17, 2008 Yeah the spare with my set of 505's was just slightly narrower than the rest but could still take the same tire as the others. (But I do not have THAT spare as I alreay had a fullsize 14" spare for mine, and someone slse needed it more) Link to comment Share on other sites More sharing options...
scoobyclimbs Posted September 18, 2008 Author Share Posted September 18, 2008 I got two pugs sandblasted/primed for black paint Dropped off two wheels to tire shop for a set of cooper weathermaster snows for now....I can't choke on swampers yet... CB swap from my outback in progress...I ran the antenna wire around the hatch and in thru one of the lic. plate lamp holes..nice and clean... I also scored a set of 53" x-bars w/ barcraffters raingutter mounts/w locks for $60...(the thule mounts are $140 + another $50 for x-bars )so my outback overhead rack with lightforce rmdl 170s, hella ff75(backup lamps) will bolt right on...just have to wire it in.. For Sat. the 4" SJR lift is goin down unda..! Link to comment Share on other sites More sharing options...
scoobyclimbs Posted September 18, 2008 Author Share Posted September 18, 2008 here's just a few pics...for now with new pugs, hatch struts(open hatch stays up), clean eng. bay, new clutch kit... Link to comment Share on other sites More sharing options...
TeamCF Posted September 18, 2008 Share Posted September 18, 2008 That engine bay is just too clean. I think I might be blind now. We'll have to get that thing on the trails and work on fixing that "problem". Link to comment Share on other sites More sharing options...
scoobyclimbs Posted September 19, 2008 Author Share Posted September 19, 2008 That engine bay is just too clean.I think I might be blind now. We'll have to get that thing on the trails and work on fixing that "problem". Ya just have to egg me on...I'm just dying to go wheelin' in my hatch..... I did get my overhead rack(from my outback) on yesterday and painted two of the pugs semi-gloss black(new treads A pair of cooper weathermaster stII studless snows) . So much to do... so little time... After I get her running I'll start workin' on the EJ22 swap and 5spd... Link to comment Share on other sites More sharing options...
TeamCF Posted September 19, 2008 Share Posted September 19, 2008 See ya saturday. We'll get that sucker lifted. Link to comment Share on other sites More sharing options...
