wildwagonz Posted August 15, 2008 Share Posted August 15, 2008 Hi, I just finished converting my 98 Outback to a 2.2....everything went well and it runs perfectly. I keep getting code PO743 and the CEL stays on. I have a OBD2 reader and keep checking/erasing the code and it comes back after you drive it. That is the only code and it says its something with the Torque Converter Electrical....something. The car did not have this code before the motor swap, but the car has been sitting for a year or so. I flushed the transmission and put in fresh fluid and that didn't help. The car shifts perfectly but will not lock into overdrive. I made sure the Torque Converter WAS seated properly before dropping the engine in as well. I have never had a code like this before, i'm just stumped. I've done lots of 2.2 conversions never with a problem. Any ideas? ~Tim Link to comment Share on other sites More sharing options...
McDave Posted August 15, 2008 Share Posted August 15, 2008 Any chance you bent the transmission pan when you jacked it up? You could have damaged the tcc solenoid or wiring inside. Link to comment Share on other sites More sharing options...
OB99W Posted August 15, 2008 Share Posted August 15, 2008 P0743 indicates an electrical problem related to duty solenoid B, which is why you're not getting torque converter lockup. I'm looking at a '97 diagram, which hopefully is the same as your '98. The wiring from the solenoid goes to pins 4 and 6 of mating 16-pin trans and body wiring connectors, and from there to the TCU connector. The 16-pin connector is "square" (four rows of four pins each), so pin 4 is at a corner. Perhaps that connector is partially dislodged, or maybe the wiring somehow got damaged during the engine work. Unless McDave is right about physical damage inside the trans, I'd suggest looking externally at the 16-pin connector and wiring to and from it. Link to comment Share on other sites More sharing options...
idosubaru Posted August 15, 2008 Share Posted August 15, 2008 OB99W gave you some excellent information and tips. i'd follow those. make sure the pins of all the harnesses are clean and seated properly. sometimes those large engine and transmission plugs are hard to get seated...like push as hard as you can and they don't seat. takes some wiggling and such. i'd look at the connectors related to this code like OB99W mentioned. Link to comment Share on other sites More sharing options...
wildwagonz Posted August 16, 2008 Author Share Posted August 16, 2008 hi, Thank you all for the tips, I checked under it and the transmission pan is somewhat bent :-( I'll pull it off and report findings.... ~tim Link to comment Share on other sites More sharing options...
wildwagonz Posted August 16, 2008 Author Share Posted August 16, 2008 Hi all..... Update, Transmission pan was dented slightly, I took it off and sure enough there was a broken wire going to one of the duty solenoids. Fixed it up and waiting for the RTV to dry on the pan....Thanks ~Tim Link to comment Share on other sites More sharing options...
Olnick Posted August 17, 2008 Share Posted August 17, 2008 wildwagonz said: sure enough there was a broken wire going to one of the duty solenoids. Quote Sounding good--sure hope it solves your problem. Nice call, McDave! Link to comment Share on other sites More sharing options...
McDave Posted August 17, 2008 Share Posted August 17, 2008 Olnick said: wildwagonz said: Nice call, McDave! Mahalo brudda. But is it fixed yet? Link to comment Share on other sites More sharing options...
OB99W Posted August 17, 2008 Share Posted August 17, 2008 wildwagonz said: [...]Update, Transmission pan was dented slightly, I took it off and sure enough there was a broken wire going to one of the duty solenoids.[...]See, McDave, you're not invisible after all. Link to comment Share on other sites More sharing options...
wildwagonz Posted August 17, 2008 Author Share Posted August 17, 2008 That was it.....Shifts perfectly Thanks! ~Tim Link to comment Share on other sites More sharing options...
wtdash Posted November 15, 2008 Share Posted November 15, 2008 Yes..older post...but i was going to post this pic the day site went down! Same Code/Same reason (bent tranny pan-broken wire)/Same result Thanks for the info...it fixed my issue! Link to comment Share on other sites More sharing options...
Tinkerer Posted August 30, 2009 Share Posted August 30, 2009 Having the same code P0743. What should the resistance be between pins 4 and 6 of connector T4? Also, does anyone know how to clear the TCU memory on the 97 Legacy Outback? Link to comment Share on other sites More sharing options...
83ROADSTER Posted August 31, 2009 Share Posted August 31, 2009 DID THE PLUG UNDER TRANY PAN FIX THIS PO743 CODE I HAVE 98 Subaru Forester THAT WITH FUEL SYS 1 IN OPEN LOOP 8.2% 84 TEMP 13.2 IN.hg INTAKE PRESSURE 1137 R.P.M. STFT BANK 1 0.0 CAR RUN GREAT UNTIL FRONT TWO CYL'S INJETERS VOLTAGE DROPS TWO ZERO! ANY IDEAS? Link to comment Share on other sites More sharing options...
