ea81 to ea82t in brat
there have been a few that have done this swap. and like GD said, you will need the turbo x-member, or you can do like i am going to do and get a custom header made for it.
you will need to not only replace the fuel pump, but hte filters, rubber lines and im not sure, but possibly the tank, but i doubt that you will have to go that far. you do need to make sure that the fuel line you use is rated for fuel injection though.
wiring will be an adventure, but shouldnt be too hard.
just remember, it will take time to get everything put together. i think the flywheel will bolt up to the engine, but i would reccomend gettting an upgraded clutch kit for the brat since you will be adding an extra 40hp and tq over the ea81, even more if you have any upgrades to the ea82t.
